VR6 side skirts ~ HELP!!!!!
OK , my standard black side skirts/ strips what ever you want to call them, are knackard, they have started to go rusty and the drivers side has gone out of shape and keep falling off everytime i open the door....... x)
I need a new set or a set of aftermarket side skirts, but am skint as at the mo and the problem being im on a stand a Max power live next weekend so need to get some asap.... :?
Does anyone have any standard ones where they have replaced them with aftermarket ones? can anyone help me out PLEASE......... :)
Guest Olly_K
lol, if you wanted people to help you should've left out the max power bit !
only joking. mine arent standard, and you can only get em from a main dealer. I had exactly the same problem, infact my door was catching it and pulling it off even more. would it be worth trying to take it off and putting it back straighter ?
how can plastic arches go rusty?!
Its not the arches, i dont have arches on mine, not plastic ones anyway, its the plastic side skirts,they are metal underneath and as olly said water gets trapped in there and they rust and the plastic pulls away from the metal ...
olly ive got the same problem when i open the door its catching on there and pulls it off........Grrrrr ~:(
And as for Max power.....pmsl...... im going up there for Girl racer and said i would go on the stand as they want girlys on there stand so thought why not, but wont be going without the side skirt......
And also theres no chance of just taking it off and putting it back on straighter, its way past that ..... :@
Here are the part numbers for o/s and n/s
1 x 1H0853853B41 MEMBREXTEN
1 x 1H0853854B41 MEMBREXTEN
1 x 1H0853985B41 COVERSTRIP
1 x 1H0853986B41 MEMBREXTEN
1 x 1H0853995B41 COVERSTRIP
1 x 1H0853996B41 MEMBREXTEN
4 x N90634901 POP RIVET
4 x N0139681 SCREW
2 x 1H0853941 STRIP
14 x 1H0853947 CLIP
10 x N0139681 SCREW
14 x N90205601 WASHER
lmao......The skirts under the door where you jack up the car......the black plastic covers that just clip on to finsh it off.....thats what im after both sides if poss, or a set of nice aftermarket ones that i can get sprayed and fitted.... :-)
lmao......The skirts under the door where you jack up the car......the black plastic covers that just clip on to finsh it off.....thats what im after both sides if poss' date=' or a set of nice aftermarket ones that i can get sprayed and fitted.... :-)[/quote']
Lol - i'm with you now! If it had been the door strips i could of helped you out with mine! One of my side skirts is falling off also - someone jacked the car up without putting it in the right place and managed to squash the sill! :@
Could be time for a nice set of M3 look-a-like skirts maybe? :D
4 x N0139681 SCREW
2 x 1H0853941 STRIP
14 x 1H0853947 CLIP
10 x N0139681 SCREW
How come there are so many parts? I thought it was just a plastic cover and a couple of screws! :P:P
Can I see what you're referring to??
Ordinarily I would make some smutty comment about you not wearing a "Skirt" or summat like that but I'll refrain on this case... However how about this for a solution......
How about using a paint stripper gun gently to "Straighten" the plastic, it is afterall only heavy plastic so it should be mouldable and therefore go back into place...
Next, Clean the surrounding area THOROUGHLY with Celly Thinners, DON'T WORRY it won't remove the paint just any dirt or polish ONLY, making sure the area is well spotless and dry!! Next you have two options here....
1/ Pending on the size of the lip or Edge, you could apply a product called "Sikaflex" available from your local Bodyshop Paint Store - price around the £6 mark! and "G" clamp the skirt to the body work until set... thats how things are professionally attached on bodywork (Look at the framework of your bonnet, you'll see big Blobs of it holding the metal together!) and it is permanent, no "Screwing" required (pfnarr pfnarr!) OR.......
2/ Using a roll of double sided tape or "Numberplate tape" available from "Halfords" price £1.50 you can apply this to the plastic and again clamp in position for a lesser while, and gently remove the clamps. It is a permanent fixing method, but not as robust as alternative 1. It's up to you Paula how you do it (No!! Not the "Screwing" or the "positioning" of the appendage pfnarr pfnarr) but it will get you by on the day without MAJOR outlay!
Good Luck! Enjoy the show, let me know what you choose to do huh?? 8o) 8o) ;):P:P
you've only just bought it paula, u cant sell it already surely? and fancy turning down a weekend at bvf with some of us for a place on a stand at lax bowel show! shamefull really when u could be having a laugh and getting merry at malvern! its not even as far as brum either!
VR6 steve~ yes its the side strips that click on and go from wheel arch to wheel arch, is that what your talking about.....??
Dubloke~ I didnt even realise that it was the same weekend , Grrrr i was asked by girlracer so i thought y the hell not had i of known then ....oh well i might not even be going yet anyway as i have still to get some skirts..... :?
Eat This~ :P LMAO the reason that i might be selling the VR is because i have another car in my sites....... not sure it will happen yet, still in talks with my friend but if it can be done then im looking at getting a mk3 golf cabby and sticking a vr6 lump into it, so i will still have a vr6.....he he either that or a audi TT lump, which ever comes up 1st....See there is a method to my madness.....ME leave the VR6 world i DONT think so..... 8o)
any skirt you wanna wear will be fine if you come along to bvf, usually a theme night on the saturday night too which is a bit of a hoot! beer can towers r us is the order of the night!
[ Edited Fri Jun 25 2004, 08:31PM ]
lmao @ dubloke..... :P maybe i will wear jeans if i come ha ha ;)
dont stick a 1.8 turbo in it stick a big throbbin 2.8 or 2.9 vr6 in it lol
Yep thats what im planning just need to find the cabby first, so if u hear of any cheapish ones about ....gis a shout :)
4 x N0139681 SCREW
2 x 1H0853941 STRIP
14 x 1H0853947 CLIP
10 x N0139681 SCREW
There are three main mouldings per side and rest are clips, washers and screws
