About 28v6r
Coatbridge/ Scotland
Its just as well Claire yer car is shown as "Going Like the wind" on the bottom photo... were you afraid that someone would pull you up for not including Passats/Sharans & Caravelles (Like Me!!! ) Why were they not included , afterall the badge at the back (Well, not on mine..) says VR6.. SO WHERE ARE THEY GAL??? ~
Just came back from the stealers with an MOT pass Yippeeee! Considering I didn't have time to check it over... Usually I have a Looksee before going in but this time I didn't stand a chance as I'm away all next week.... Booooo! Still, Legal for another year... but the sad news is that I'm thinking on selling up and moving on... The car has a new legal 12 months and 6 months tax, and runs a peach now.... Any body interested?? There are only 53 Estates in the country and only two in Scotland, I'm one of them...
Weird Engine noise at 3900-4000 Rpm
28v6r replied to Norrisvr6's topic in Engine Maintenance and Problems
A couple of questions... Does it happen under load i.e in gear? Or can it be replicated stationary? If the second, try putting a long screwdriver to where you think the sound comes from and put your ear to the end of the screwdriver and listen ... Then tell us what you find.. -
Doh! Obviously Alzheimers at 30.. Tis' a sad day.. read the post again.. it says "Birthday Snogs" what do you generally get at birthdays from a female (or give a female)? a Birthday kiss on their birthday and wish them all the best, hence in your case being male " a simple hand shake will suffice" i.e I'm not into kissing guys! With me now?? or did that hurt??
Its a pity you're not visiting Scotland in the near future ( .. could have properly buffed it all out for nought! Have all the right tools and polishes to restore it for you.. pity really... !sad
Yaaaaayyyyyy!!! Birthday "Snogs" all round !heart ... Great Claire have a Good Un' .... Oh! and Jezmoz ...your alright, don't need to go that far, a simple handshake will suffice
Exactly!!! Loctites an amazing thing..
Unfortunately matey ...the bad news... the window problem is the control unit on the regulator thats US. The only fix that I'm aware of is a whole new regulator @ £170+ . mine did exactly the same when I got it and that was the only fix I could get as Passat regulators on the driverside are like Rockin' horse doo doo!! !grr !sad !sad As for the CD thing, check your connections at the back of the head unit, in particular the live connection, mine also did this although not related, however I can't remember how I fixed this...it was sometime ago... !sad
What do you mean "has gone quite stiff" ? Difficult to engage, clutch is heavy, gear selector stiff or what.. can we have a little more detail please?
If you order a set of hoses, do you get a matching colour co-ordinated sticker (thats on the back lead rail) as well??
I'm impressed big boy!! Holding the camera with what, AND having two women over the desk at the same time... Feckin' amazin!! Oustanding Lee...
Whats That on your nose Nikki?? Looks awful..... 8)
91k and not out....just had some TLC on it recently though and now the wallets screaming at me....Aaarrrrgghhh!!! !amazed
Do the routine test, spray the coil pack lightly with water to see if the coil pack is cracked, the misfire will appear...once done you could always dry the coil pack outwith a strong heat, spray liberally in WD40 then coat in Silicone Grease or epoxy resin... RE: The backfire could also be the lambda probe failed or a choked Cat..The lamda probe would cause the car to overfuel hence rich, hence backfire...
Give this a go!! EYE - HAND COORDINATION TESTER ... The object of the game is to move the red block around without getting hit by the blue blocks or touching the black walls. If you can go longer than 18 seconds you are phenomenal. It's been said that the US Air Force uses this for fighter pilots. They are expected to go for at least 2 minutes. Give it a try!! http://tinyurl.com/56t9u
