RsvRob
Days Won
1
Everything posted by RsvRob
Where is you wideband located? If it's in the tail pipe then I've seen plenty between 16-21 on idle. But it's fine when wot. You seem to be testing half a job. Get it all plugged up and any leaks you know of sorted 1st then take it for a drive to test for correct readings. Sent from Dagobah
Check the resistance with an volt meter on ohm setting Sent from Dagobah
On a 95 mk3 golf. I wouldn't expect any such luxury as economy or sport mode. Pic of the switch your referring too?? Sent from Dagobah
Use a wideband afr reader to check fueling via your exhaust. If it's ok then not to worry. If the ecu is not registering a signal from the lambda then it should switch to closed loop and just use the fuel map rather than use the lambda You may find you haven't fitted the correct sensor. Lambda's aren't all the same. You'd need to find the correct matching sensor from oem. Sent from Dagobah
Any way of checking your afr's on cruise?? Sent from Dagobah
Depends on the limits of the block. The machine shop should have all the specs for tolerances regarding minimum thickness for cylinder walls. I don't particularly know the answer. But I would think that as they already do a 2.9. Then boring it out to accommodate larger pistons there by making it a 3.0. This wouldn't be a massive difference in piston size to accommodate 0.1-0.2 increase!!! Sent from Dagobah
Cylinder Head skim / pitting
RsvRob replied to EnthusiastOwned's topic in Engine Maintenance and Problems
Speak to the machine shop doing it. They'll confirm if it's useable. The head will have a minimum thickness before its to thin and will cause the valves to hit pistons. Sent from Dagobah- 10 replies
- Cylinder head
- head
(and 4 more)
Tagged with:
Rear discs part corroded, advice needed.
RsvRob replied to ssaunders's topic in Wheels, Brakes, Suspension and Steering
Simple answer yes Sent from Dagobah -
Metal Headgasket - Which sealant / spray?
A properly skimmed head and decked block. With New bolts and gasket will seal correctly if fitted correctly. No need for any kind of sealant. Sent from Dagobah- 9 replies
- Headgasket
- metal headgasket
(and 2 more)
Tagged with:
They may have different threads. But I've not found any car I've worked on to have this. Sent from Dagobah
I'd like to think they are same length or you'd have steering problems!!! Sent from Dagobah
Have tried fitting a stereo in the car today but came across a strange problem. The std harness was connected to a radio harness to plug directly to stereo. But the ignition and power were wired directly to power. I know vw switched the power and ignition from a std setup. But unless the stereo is wired with both going to power only. Then I have nothing. I have tried a volt meter to see what happens on the std harness. But I get nothing when I earth it and turn ignition on. Ideas?? Sent from Dagobah
Think I've found it on a pdf file Sent from Dagobah
I can set it up but want to know std settings for a base setting to start from. Thx Sent from Dagobah
No one have this information?? Sent from Dagobah
What's the std setup? And what's a prefered setup? Thx Sent from Dagobah
I have a usb stick that's as small as a 5 pence piece and still holds 8gb Sent from Dagobah
Just buy a newer better Sony head unit!!! Sent from Dagobah
Relay or earth would mean they don't go up no matter what you do as its part of the same circuit. Your just using an alternative switch. Sent from Dagobah
Is there a breather on the catch can? Sent from Dagobah
Pcv valve should be inline on a hose from rocker cover. It should go back into the intake system. If you've now fitted a catch can. You need to block where the hose was going to on the intake side. So what you've done is fit New hose from rocker to can then back to intake?? Sent from Dagobah
I would suggest something isn't seated properly and it's sucking in to much air. Or your new gaskets have a leak. Sent from Dagobah
Sorted. Despite it being a vacuum type. It's wired as a positive system. And the green and grey wires in the car are wrong way round. I kept locking then dead locking it. Not unlocking it lol Sent from Dagobah
Which of the 2?? Sent from Dagobah
Ok but the other info I have for fitting a cl kit to the golf shows 2 wires for open/close. But my wiring diagram for a pump shows connecting 1 wire!! Sent from Dagobah
