About Madrocker
Nuneaton, warwickshire
honestly you can pick up a good vr for relatively little money compared to other cars. you would spend a small fortune converting a mk2, if your patient you would pick up a mk2 vr6 that's already been done. a lad on here not long sold his mk2 vr6 for £2500..
Lol that was HOT, Now that's a case where a bonnet scoop would actually be a good idea.
All post 1992 cars had to have Cat's by law and as the Vr6 line started in 92 then yes they all have Cat's.
if the bonnet locks closed and opens properly then it will pass an MOT as long at the edges aren't sticking out loads
I didnt know that ODBII's dont have an ISV. The EGR runs directly from the exhaust to the inlet manifold somewhere, or at least the ones I have seen have. I personaly dont like them because it reduces power and not adds it in the strictest sense. It will reduce combustion chamber temps which reduces NOx but it also dilutes your air-fuel mixture with unmetered air so you get a weaker explosion thus less power. Its purpose is to send exhaust gasses back through the intake system to be re-burnt. This in itself will line the inside of the intake with exhaust which will also distrupt the air flow
Vr6 engine bucking under throttle
Madrocker replied to Goguvarra's topic in Engine Maintenance and Problems
Oh I didn't realise ODBII did'nt have one, My apologies. -
Vr's do idle low anyway, when mines warm it ticks over at around 500rpm. I don't really know what to say about your flat spot, how far does it go on the revs?
Hey Goguvarra, From you're other thread I think your problem is that you're ISV valve has been removed and bypassed. If that is the case then get one fitted back in and all should be well. Cheers Dave -
The bottom right circled part is the Aux water pump witch on you're car has been removed and bypassed (probably due to failure and the last owner didn't want to pay to replace it). The 2nd circled part in the middle is part of the EGR system, it is a stupid "environmental" system that esentually pipes exhaust gasses back into the inlet manifold to bring down emissions. the last circled part top left is the idle stabilisation or air control valve (ISV) The EGR system is not fitted to all Vr6 models, My 94 Vr doesn't have one and in my opinion its better off without them for obvious reasons. As
it is normal, with such a big engine crammed into a small engine bay the heat soak through the firewall is a common problem. I remember reading about it when I was researching the vr6 before I bought one.
I'll come and say hello being as I live in Nuneaton
my First car, a 1000cc mini aparently doesnt exist anymore, Reg: oxc130m. But my old landrover is atill around!!! The enquiry is complete The vehicle details for WAT 788J are: Date of Liability 01 08 2011 Date of First Registration 01 10 1970 Year of Manufacture 1970 Cylinder Capacity (cc) 0CC CO2 Emissions Not Available Fuel Type Petrol Export Marker Not Applicable Vehicle Status Licence Not Due Vehicle Colour RED
Yes that Helicoil kit will do the trick mate, or just take the head to your local machine shop and they will be able to sort it no problem
A444 Bedworth to Nuneaton - Unmarked Gun metal grey Golf R32. patrols weekdays 8am - 7pm I've seen this car stop a few people over the last few weeks, always between 8am and 7pm, never seen it on a weekend yet. M6 junction 3 Unmarked Blue Ford Focus ST, I Regularly spot this car cruising up and down the junction 3 area of the M6
HELP HELP Garage Knacked my Car!!!
Madrocker replied to grantnunn's topic in Engine Maintenance and Problems
when the car is running its on the MFA, press the button on the right column leaver until the LCD screen displays the oil temp. Just so you know it wont read anything until your oil gets to 80 degrees i think it is
