About danb
Wigan
stunning car m8y ! dont mean to be cheeky but how much did prospray charge you for the arch work cos irlam not to far from me and i need mine doing asap ? oh were abouts in irlam are they ?
the one wire you have is the positive wire , you need a ground wire , when i changed my wheel i trapped a ground wire underneath the 24mm nut then attach it to the spade end connecter on the back of your horn !
thermostat housing & coolant pipe
danb replied to montevr6's topic in Engine Maintenance and Problems
i got mine as a kit all the seals , everything needed from www.pap-parts.com , thier in america but the kit cost me $80 posted thats about £42 only thing is it took about 3 weeks to come ! -
It started about 2 weeks ago when id been out in the car for a while and then i took the gf to tesco and when i was reversing into a space the car cut out and wouldn't fire up , it was turing over though . After a couple of minutes it fired up and ran fine . then last wednesday pulled up at some lights and it cut out again but started straight away . Anyway i give my car to a guy at work to sort a leak out from the thermostat housing and he said that he filled the car up with water and G12 and ran the car for a couple of minutes then turned it off and left it to cool then topped the water up a
JL,Focal or cerwin vega
is your earth and ignition live feed not mixed up ?
what this splitter is ? http://img.photobucket.com/albums/v338/danbrs2k/media.jpg
cheers, will go for the cheapest things 1st . we use pink coolant at work in the jags , wonder if its the same stuff ?
im losing water from my header tank , ive only had the car a week and its used a litre of water but ive had a good look round the engine while it was running and couldnt see water coming from anywere ! just wondered if any of you guys might know what it could be ?
jack the front end of the car up and stick your head under the front bumper and look up the front of your engine and see if you can see the bonnet catch and use a bar of some sort to release the catch !
i live in westhoughton , small world !
think ive seen your car going through farnworth , ive got a vento aswell !
sound like the hinges are fooked ! do these bolt on or use a pin with welded hinges ? open the door and wiggle it up and down , you should be able to see exactly were the play is !
