About montevr6
london
is that not purge canister...
hi mate,i have taken that breather pipe off my charger inlet i think its not good for my charger,you can get catch tanks.can get abit fumes under bonnet makes less mpg.
what engine oil do you use?
montevr6 replied to badboygolfvr6's topic in Engine Maintenance and Problems
i use fully syn in my vr sc,with the lucas friction treatment good stuff abit pricey tho, and change oil about 5-6 000. -
My vr?
Retardation Relay for Fuel Pump. What is it?
montevr6 replied to thegoth's topic in Engine Maintenance and Problems
what i did is drove it to vw bought the relay slaped it in.notice the difference straight away.when igot home took earth lead off for few hours. the relay problem blew my alarm imobolizer too, another thing you need to be careful about is the relay is dosent matter if the relay is new aparently some were faulty. good luck sorting it. -
hi mate Ive got a valver for every day driving, i had a misfire problem when engine was hot between 3 4000 revs Changed the usual stuff,coil,leads,plugs. manage to sort it after pulling all my hair out. on mine it turned out to be the ecu feed relay.Ask vw maindealer,the plonker said no such part, so had to tell him to keep his expert knowledge to himself and do his job and look on the computer. it was the best £10 ive spent on my car. if you need part no.. hopefully tomorow. Hope it helps -
The samco kit replaces the crappy plastic part. A friends vr6 was leaking managed to use one from another mk3 not vr6.scrappy stung us for £20.
you have to order it from states. nice bit of kit.
[poll] London Rolling Road Day?...13th Jan 08
montevr6 replied to vr6newcomer's topic in Previous Events
put my name down. -
Hi all had a chance to tare a friends 06 st focus turbo,before it went back to fords i dont get many chances like that,just sad didnt have it for longer,not a big fan of fords. but very surprised.strraight line sub 6sec .wicked on roundabouts and bends ,tc lets you have fun.you are more busy behind the wheel to keep the boost up,makes you feel like your rallying.. very juicey 10 mpg on a hard slap. i would have a R32 anyday.
focus st, good race,should win, top end audi s3 wins on roundabouts,straight line you can catch him...comes down to driver. mg da no new focus st dont bother.good fun.220bhp
VR6Pete's Golf Mk2 VR6 Conversion [Finished]
montevr6 replied to VR6Pete's topic in Members Rides and Event Photos
hi mate pete you thought about doing mk2 vr?,it should be blooby with your lump.you alreedy got donor car.cost less maybe? good luck. nice pics. -
trying to track down a water leak, turns out the thermo housing is absolutely buggered, also will be needing a replacement coolant pipe ( with drain valve) any ideas? and are these parts available at ford?
got to say your car is a beast.its good to a vr taken to next levels,at gti fes 06 u said more to come did nt think this much,hats off mate keep dubbing.
