CorradoVR6-n.o.s
About CorradoVR6-n.o.s
out of time
As above i suspect i have a faulty ecu but would like to try it on a working car....it will tack 10min max! Booze or money is offered! Cheers James
Eaton supercharged VR6
CorradoVR6-n.o.s replied to LarkinBoy's topic in Members Rides and Event Photos
any updayes on this? -
bastards! thats why i drive a shitty daily and keep the toy locked up only to come out on sunny days where i can keep an eye on it when its parked up. Sad but its so true.
see i said C2 are good!
its the top pole of the sloenoid.
Clicking starter motor
CorradoVR6-n.o.s replied to MarkGolf's topic in Engine Maintenance and Problems
try jump start it first,its sounds like aflat battery. -
its a stronger 6 speed bix,its big and heavy and needs mounts to suit it,but they are fitted to the 4wd variance with the VR type bell housing....but it has a transfer box on....thats the problem. I dont know if the transfer box can simply unbolt and you can fit a normal drive shaft in?
im sure its the vw touran.
yea the o2j bolts straight it but has no speedo drive as it takes it off the abs,so you would need to swap your original housing over.
02a mate but an 02j would fit too but hard to find one and its six speed.! Any box from a VR6 model will fit mate bar the later 24v's but they can be fitted but its not a straight in and out job.
423 BHP - It works!!!
CorradoVR6-n.o.s replied to supersix's topic in Members Rides and Event Photos
a right,thanks! Should have looked at your sig first lol! -
New schimmel cams have made my car slower. Help!
CorradoVR6-n.o.s replied to Cuske's topic in Engine Maintenance and Problems
yip...they have been fitted incorrect or the cam sensor wheel trigger is on the wrong cam or left off. -
2.9 24v? whats that all about then>? Nice numbers!
