mtopple 0 Posted September 26, 2005 Report Share Posted September 26, 2005 info please, has anyones car drinks water over the summer, I would say since July I've had to refill my coolant twice. The car never overheats and the performance has not suffered but it does drink a bit of water, is this norm??Had the head gasket changed when I got the engine rebuilt in July so just thught if anyone else VR has been thirsty over this warm summer we have had. FYI I do around 2k per month on miles due to business Link to post Share on other sites
Eat this 2 Posted September 26, 2005 Report Share Posted September 26, 2005 any leaks?? Link to post Share on other sites
dubloke 4 Posted September 26, 2005 Report Share Posted September 26, 2005 look for leaks first off as eat this says! favourites are the thermo housing itsefl as they are prone to cracking, and the aux water pupm sometimes develops a leak too. and the head gasket to, but you say this has been done. lets hope its been done well, take it there's no oil in the header tank normally? Link to post Share on other sites
mightyvr6 0 Posted September 26, 2005 Report Share Posted September 26, 2005 check the main water pump and transfer pipe too! Link to post Share on other sites
Vimto Vento 0 Posted September 26, 2005 Report Share Posted September 26, 2005 Also worth checking is the header tank as well. Mine split along the seam, replaced it, this caused the coolent system to pressurise as it should, blew the thermostat housing..... Just a warning... Link to post Share on other sites
Nerih 0 Posted September 26, 2005 Report Share Posted September 26, 2005 yes, all of the above are the common ways that water leaks out of ur vr. to check the water pump, just see if its running straight (or if it wobbles), water should be leaking out of it if its going. also that thermostat housing, somtimes it cracks right under neath it, and its REALLY hard to see where its coming from, i'd use some UV fliud and leave it in your cooland and try to find it the day after using a black light. Link to post Share on other sites
mtopple 0 Posted September 26, 2005 Author Report Share Posted September 26, 2005 I'll look for a leak over the next few days, I got to admit I haven't seen any but not looked hard enough. The company that rebuilt my engine is Storm Developments, if I can't find any leaks I'll get them to do a once over. Cheers!! Link to post Share on other sites
Nerih 0 Posted September 26, 2005 Report Share Posted September 26, 2005 hope you havnt got water injecction thru the head gasket hehe Link to post Share on other sites
