Crossy 6 Posted January 8, 2014 Report Share Posted January 8, 2014 Checked my ht leads as I have a misfire around 1200/1500 rpm all leads read about 6.2kohms but autodata recons it should be between 3.6/4.4kohms also checked the plugs and denso k20txr are fitted what plugs and leads do people recommend ? Sent from my iPad using Tapatalk VR6Pete 1 Link to post Share on other sites
mattvr6 133 Posted January 9, 2014 Report Share Posted January 9, 2014 Standard leads I had magnacor on mine had nothing but shit with them not fitting right and coming off under hard acceleration plus they don't fit in the oem holders waste of £130 I use ngk iridium plugs and standards ht's runs sweet as. Sent from my iPhone using Tapatalk Link to post Share on other sites
Crossy 6 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Called tps and got new plugs but the leads were £165 +vat and the guy said he doesn't rate them I have saw a few sets on ebay anybody used them? Standard sets or uprated sets ? Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Lukey. 381 Posted January 10, 2014 Report Share Posted January 10, 2014 TPS don't know what they're talking about Vince12v 1 Link to post Share on other sites
mattvr6 133 Posted January 10, 2014 Report Share Posted January 10, 2014 Try gsf if u have one near you that's where mine were from Sent from my iPhone using Tapatalk Link to post Share on other sites
Therusterman 59 Posted January 10, 2014 Report Share Posted January 10, 2014 I picked up a set of leads from eBay for around £40, have been fine since I fitted them a few months ago and cured a misfire I had at similar revs to you. Link to post Share on other sites
ssaunders 199 Posted January 10, 2014 Report Share Posted January 10, 2014 I picked up a set of leads from eBay for around £40, have been fine since I fitted them a few months ago and cured a misfire I had at similar revs to you.Same here, also using the right tool is a must! S Therusterman 1 Link to post Share on other sites
Lukey. 381 Posted January 10, 2014 Report Share Posted January 10, 2014 Metal not plastic! Link to post Share on other sites
Ickyketseddie 89 Posted January 11, 2014 Report Share Posted January 11, 2014 I got dubpower leads. They were pretty cheap and seem to do the job. Not done many miles since to be fair though. Sent from my iPad using Tapatalk Link to post Share on other sites
daveyboy 897 Posted January 11, 2014 Report Share Posted January 11, 2014 I've got dub Power leads too and they seem spot on. Done a few thousand mile with them now and all's goodSent from my LT26i using Tapatalk Link to post Share on other sites
Ickyketseddie 89 Posted January 11, 2014 Report Share Posted January 11, 2014 Not to mention £35 + p&p! Sent from my iPad using Tapatalk Link to post Share on other sites
PeteVRT 22 Posted January 12, 2014 Report Share Posted January 12, 2014 I used GSF around 60 quid at the time, but recommend a bit of contact grease when fitting. They tend to stick on and not using the tool to remove they break easily. Went through several sets as I didn't remove them regularly enough and seized on, Link to post Share on other sites
Lukey. 381 Posted January 12, 2014 Report Share Posted January 12, 2014 Top tip, when I pulled some cheapy ones off to swap plugs the ends came off the leads. You referring to silicon dielectric grease? Link to post Share on other sites
Crossy 6 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Changed the plugs no difference gonna get a set of leads Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Crossy 6 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Formula power leads keep coming up on ebay they say they are uprated anybody used them ? Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Crossy 6 Posted January 14, 2014 Author Report Share Posted January 14, 2014 Ok bit of an update changed the ht leads £25 + vat feom eurocar parts and still no difference now I dont rhing its ignition because it only seem to happen when after revving feom idle or hard acceleration so I think its thw fuel filter ? Will try to get one tomorrow fuel pump doesn't seem noisey though. Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Crossy 6 Posted January 15, 2014 Author Report Share Posted January 15, 2014 Changed the fuel filter still the same does the fuel pump have a seive on it or does anybody else have any ideas ? I checked the maf its ok as is the coolant temp sensor and checked for codes and none came up? All help appreciated as its doin my head in Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
B7D VR 35 Posted January 15, 2014 Report Share Posted January 15, 2014 Omg !! I have the same problem. When I pull off it misfires from 1300-1500 rpm and that's it. When past that its all fine. If you find out the problem please let me know. Thanks Babs Sent from my iPhone using Tapatalk Link to post Share on other sites
EnthusiastOwned 7 Posted January 16, 2014 Report Share Posted January 16, 2014 OEM leads are now obsolete! VR6Pete 1 Link to post Share on other sites
Therusterman 59 Posted January 17, 2014 Report Share Posted January 17, 2014 Sure your coilpack isn't on the way out? Link to post Share on other sites
Crossy 6 Posted January 18, 2014 Author Report Share Posted January 18, 2014 I dont think its electrical because it feela flat in general when it's not misfiring it seems to hold back thats why I thought possible fuel a tyre fitting van killed me thw other day it was embarrassing Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
EnthusiastOwned 7 Posted January 19, 2014 Report Share Posted January 19, 2014 Still sounds ignition related to me. Coilpack would be my next bet.Then I'd be looking at the cam sensor. They can cause misfires, flat spots and sap around 20-30bhp.Then I'd be into the MAF sensor. Link to post Share on other sites
PeteVRT 22 Posted January 19, 2014 Report Share Posted January 19, 2014 I had a similar problem, just felt really sluggish. Not misfiring, that was the cam sensor but was showing a fault on it when the diag was plugged in Link to post Share on other sites
VR6Pete 1,455 Posted January 25, 2014 Report Share Posted January 25, 2014 Smells of a coil pack problem this Club Chairman Link to post Share on other sites
Crossy 6 Posted January 29, 2014 Author Report Share Posted January 29, 2014 Well after half tank of the new fuel its been ok until today started missing again will order a coilpack tomorrow also out of interest mpg seems a bit low only got 95 miles to half a tank ? Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
