About Crossy
Walsall
Misfire on low revs suspect ht leads ?
Crossy replied to Crossy's topic in Engine Maintenance and Problems
Well after half tank of the new fuel its been ok until today started missing again will order a coilpack tomorrow also out of interest mpg seems a bit low only got 95 miles to half a tank ? Sent from my GT-I9300 using Tapatalk -
My local tps have a sign up saying you must prove id to use your account but they have never asked me Sent from my iPad using Tapatalk
Pete if you want I can forward the email from cobra so you could make it a sticky? It may help other people because it took me ages to talk to someone who wanted to help Sent from my iPad using Tapatalk
Ok car still not on the road so I spoke to cobra alarms technical division and they have sent me the paperwork which tells you how to sync fobs to all cobra alarms for the past ten years unfortunately for me my alarm was fitted when the car was new and the fobs came pre coded to the car and all the parts for my alarm are now obsolete so I have a guy coming today to remove my old one and fit a new Clifford cat 1system was the only way I can get the car back on the road Sent from my iPad using Tapatalk
VR6Pete reacted to a post in a topic: Misfire on low revs suspect ht leads ?
VR6Pete reacted to a post in a topic: Cobra alarm
Hi everybody was gonna take the car out for a run today and the fob does not work the key works but I didn't want to open it because the alarm and immobiliser are on so I changed the battery on the fob and it still doesn't work any ideas it's a cobra 5557 I have searched google but nothing comes up it was fitted when the car was new I'm starting to get very annoyed with this car it's one thing after another! Help much appreciated Sent from my iPad using Tapatalk
I dont think its electrical because it feela flat in general when it's not misfiring it seems to hold back thats why I thought possible fuel a tyre fitting van killed me thw other day it was embarrassing Sent from my GT-I9300 using Tapatalk -
Changed the fuel filter still the same does the fuel pump have a seive on it or does anybody else have any ideas ? I checked the maf its ok as is the coolant temp sensor and checked for codes and none came up? All help appreciated as its doin my head in Sent from my GT-I9300 using Tapatalk -
Ok bit of an update changed the ht leads £25 + vat feom eurocar parts and still no difference now I dont rhing its ignition because it only seem to happen when after revving feom idle or hard acceleration so I think its thw fuel filter ? Will try to get one tomorrow fuel pump doesn't seem noisey though. Sent from my GT-I9300 using Tapatalk -
VR6Pete reacted to a post in a topic: 5 Months sorn and now shes on road
Surreyvr6 reacted to a post in a topic: 5 Months sorn and now shes on road
Hi All just an update brought a vr6 a while back now and it was cheap but a bit neglected so i had some work to do after checking it out at work. Found a broken spring and exhaust loose and various bits of trim hanging off also a bad internal water leak so i have been busy and now finally taxed & tested. 1st thing i did was change the coilovers they had jom fitted and were in a bad way a n/s/f broken spring and all set at differant heights resulting in a crap ride and tyres scuffing while i was there i changed the oil didnt have a filter but didnt matter she wasnt going anywere. i managed
Formula power leads keep coming up on ebay they say they are uprated anybody used them ? Sent from my GT-I9300 using Tapatalk -
Changed the plugs no difference gonna get a set of leads Sent from my GT-I9300 using Tapatalk -
Anybody based Midlands area ? Sent from my GT-I9300 using Tapatalk
Had this on my vr rear carpet was soaked tbf thought it wad the tail gate but was a splut gland on the o/s/r lamp Sent from my GT-I9300 using Tapatalk
Called tps and got new plugs but the leads were £165 +vat and the guy said he doesn't rate them I have saw a few sets on ebay anybody used them? Standard sets or uprated sets ? Sent from my GT-I9300 using Tapatalk
