Now chaps I have done quite a bit reading on here since I first registered and learnt quite a bit regarding my latest VAG,
However,
I presume since my motor is 24v and red lines around 6-7k sureley it should not be running out of puff at around 4K??
I have done a full scan with my basic Vagcom resulting in this,
VAG-COM Version: Release 409.1-US
Control Module Part Number: 022 906 032 B
  Component and/or Version:  MOTRONIC ME7.1     V006
           Software Coding: 00132
            Work Shop Code: WSC 31440
6 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
        P0118 - 35-00 - -
16497 - Shareware Version. To Decode all DTCs
        P0113 - 35-10 - Please Register/Activate - Intermittent
16486 - Shareware Version. To Decode all DTCs
        P0102 - 35-10 - Please Register/Activate - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
        P1602 - 35-10 - - - Intermittent
16891 - Shareware Version. To Decode all DTCs
        P0507 - 35-10 - Please Register/Activate - Intermittent
17550 - Shareware Version. To Decode all DTCs
        P1142 - 35-10 - Please Register/Activate – Intermittent
I cleared then and went for a mixed drive slow and steady and more exuberant on the dual carriage ways within the law of course,
Then found these,
Control Module Part Number: 1J0 920 922 F
  Component and/or Version: A4-KOMBIINSTR. VDO V26
           Software Coding: 05464
            Work Shop Code: WSC 00468
           Additional Info: IMMO-IDENTNR: VW************
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
        30-10 - Open or Short to B+ - Intermittent
01176 - Shareware Version. To Decode all DTCs
        07-10 - Please Register/Activate – Intermittent
Its coming up with these two air temp sensors G17 and G62 are either of these the blue sensor that keeps cropping up?
I am in the process of googling the rest of the fault codes to find out whet exactly is wrong,
Also can anyone tell me what exactly the secondary air pump does and can I remove it??
Cheers in advance for any help you can offer :) :)
I see Coulstar I have been running TDi's for the last ten year so its just the nature of the beast it does pull very hard upto 3-4k and as you just tails off.
Cheers hopefully the other faults will help my MPG .............................................a little.
Cheers Lukey,
Your post about the variable geometry inlet gave me an idea, If mine is faulty then that would explain the drop off in power at high rpm's so I did a little gooogling  found this on Vortex
The thread is about turbo charging I believe but this post strengthened my theory,
Qoute:-
It's easier to read the full sized version.
The colors are red and light red.. blue and light blue.. and so forth.. Anyway.. What's interesting about this is that the variable manifold
isn't a true long runner/short runner configuration, in that air
does not actually *flow* through the "long runners" in any volume.
The intake shifter rod just opens up a passageway to a resonator
chamber. This shows it
Green is actual airflow into the engine.
Blue is the path of the pressure/sound pulse that occurs when the inflowing air
bounces off the closing intake valves. The pulse travels up through
the open shifter rod into the resonator chamber where it is reflected
straight back (red) and arrives at the intake valve when it's next open. That
pulse actually helps *cram* some more air into the cylinder. A car
with a good variable intake can acheive a VE > 1.0 at certain
rpms, using this trick or a variation of it.
Anyway, what's amazing here is that with the shifter rod held open,
in the long runner configuration that there's such a HUGE decrease in
power at high rpms. The reason this dyno is confusing to look at, is
because it's down 40 lb-ft at 6000 rpms, and 60 hp at 6500 rpms.
That tells me that at the high rpms, the reflected pulses are actually
pulling air away from the intake valves instead of pushing it in.
Unqoute:-
So tomorrow I fit the sensors and check all the linkages control arms and what not regarding the throttle shifter rod in the inlet and of course the secondary air which may well find itself flung into some corner of the shed..............
Edited by Airone
  • 10 months later...
Well I have been running this for a while now and find this power restriction is getting worse all the noise with no lift my 110 afn tdi is quicker,
I have addressed all of the results above and am starting to wonder if the cat or rear silencer is causing a restriction in the exhaust resulting in a huge loss of power.
Anyone had this problem???????
When I first got mine, it was holding back as you describe, I also scanned it with shareware software, once I did a proper scan with a genuine VCDS Ross Tech cable a lot more codes showed up, the problem my car had was the lateral sensor on the bulkhead, I changed this and the car was completely different.
 I went on to replace the Lambdas too, this also made a huge difference, full VCDS will show which one is the problem.
 As said, your engine should pull well to the red line.
  • 3 weeks later...
Right sorted a full scan and this is what came up,
I already fitted a new airflow meter but apparently it has to be a proppa Bosch part so I'm gona try a bosch airflow meter and the oxygen sensor,
Any idea which is bank 2 sensor one and were is the camshaft sensor?
Cheers fella's........
I've heard that only oem is a suitable replacement for the maf and also that a faulty maf will throw other codes too, start with the maf and get the codes cleared and then rescan if you've still access to the scanner, although for the cost of the lambda probe, you may as well replace that and then clear the codes, fingers crossed it will sort your issue!
WELL!!!!!
Put a "used" Bosch air flow meter on a shit a brick what a difference it pulls all the way to the red line and doesn't lett! gets to about 4.     4 1/2 and its like hitting the power band on my old KX250 crosser......
What a machine I can't believe the difference mind especially after spunking  90 quid on a brand new pattern part last year...
Just hooked up the trailer and dragged a transit pickup up the yard to weigh in and it was like towing a little up! or mini ( BL Mini that is ) or summat the thing just pulls and pulls........
Very happy bunny!! it can do 10 mpg for me I like it very very lots!!!!!
Might even fix the rear arch now.........
Edited by Airone
