Moochalargo 0 Posted March 6, 2012 Report Share Posted March 6, 2012 A few weeks ago my belt tensioner seised and shreded the belt I had to drive it a bit and cooked the engine. I ended up having to replace head and gasket ect But then after when all should have been good I got loads of cream in the header tank shed loads so I cleaned out and flushed with all kinds of stuff and ended up with clear water. After driving for another 20 to 30 miles I now have oil that looks like white coffee and oil in the water again!!!! AggghSo today I've taken the head off and even though it's supposed to be fine im getting it skimmed and another head gasket set and bolts but some one said the oil cooler may be broken!! Guys do you know or should I roll the car over a cliff somewhere?Been told the oil cooler could be broken and did find a bit of rubber gasket coming out one of the water ways!!Is this my problem and have I removed the head for no reason?? Week confused and running out of money fast!! Link to post Share on other sites
cabrioman 6 Posted March 6, 2012 Report Share Posted March 6, 2012 it could be the oil cooler yeah or could be the head deformed .... if i was you id get the head skimmed and replace the oil cooler Link to post Share on other sites
legvw 0 Posted March 6, 2012 Report Share Posted March 6, 2012 I'd always have a head skimmed if the engine got over temp, also the head maybe cracked somewhere which would need testing to eliminate. Did you torque the bolts correctly? And clean the mating faces properly? Link to post Share on other sites
Moochalargo 0 Posted March 6, 2012 Author Report Share Posted March 6, 2012 Head is being skimmed and I'm getting all new bolts gaskets and an oil cooler. I'm sure I got the bolt sequence right and I read the torque settings were. 35. 45. 90 degrees. 90 degrees. When I removed the head again the middle row of bolts squeezed and cracked as I moved them but the inlet and outlet sides didn't feel half as tight???Also local machanic said the head gasket didn't look as squashed as he would have expected!!?? Link to post Share on other sites
cabrioman 6 Posted March 6, 2012 Report Share Posted March 6, 2012 did you clean out the threads in the block and lube the bolt heads and washers to avoid the cracking when torquing them up ??? Link to post Share on other sites
CALICO 130 Posted March 6, 2012 Report Share Posted March 6, 2012 I Had my head gasket done but still had leaking turned out the head was warped had it skimmed and all is fine now. I was lucky i did not have water/oil contamination. Link to post Share on other sites
Moochalargo 0 Posted March 9, 2012 Author Report Share Posted March 9, 2012 Skimmed the head. New gasket set. New oil cooler. COMPLETLY skint now and after ten mins of running the oil is coffee coloured and oil in water again!!! Wtf is going on? Feeling so shit I'm close to scrapping the car now!! Link to post Share on other sites
russj249 2 Posted March 9, 2012 Report Share Posted March 9, 2012 Are you sure this isn't just hinge that's come out of the heater matrix and radiator from last time? Drain all the coolant and refill with water, just keep flushing it through. Link to post Share on other sites
russj249 2 Posted March 9, 2012 Report Share Posted March 9, 2012 Sorry.. just noticed that you say oil was contaminated too. Link to post Share on other sites
v6horse 1 Posted March 11, 2012 Report Share Posted March 11, 2012 Did you have the head checked for cracks ? Link to post Share on other sites
Moochalargo 0 Posted March 11, 2012 Author Report Share Posted March 11, 2012 The car over night dumped loads of water in to the oil!!What is going on?? It's crazy!!! Can the crank case be shot or is the head got issues! Got this head from some git on eBay telling me it had only done 68k and had nothing wrong with it!! Link to post Share on other sites
cabrioman 6 Posted March 11, 2012 Report Share Posted March 11, 2012 could be either hard to know with out testing did you get the head pressure tested ???? Link to post Share on other sites
Moochalargo 0 Posted March 12, 2012 Author Report Share Posted March 12, 2012 No that's my next step. Get it crack tested!!Going to leave it for a bit as I'm just throwing money at it now and nothing is working. Could have r32'd it by now the money I've wasted!!!Can I reuse stretch bolts? I've purchased two sets now!!!??? Link to post Share on other sites
rsweeney 40 Posted March 12, 2012 Report Share Posted March 12, 2012 cant reuse stretch bolts as once the bolt has stretched the metal of the bolt has also stretched. defo get it pressure tested as youve covered most of the oil and water related bits . couldnt it be the water jacket on main block that is leaking or cracked thats letting water and oil mix?saw where it had happened on a daihatsu i owned previously Link to post Share on other sites
Moochalargo 0 Posted March 12, 2012 Author Report Share Posted March 12, 2012 Does a vr block have a water jacket? Link to post Share on other sites
Moochalargo 0 Posted April 26, 2012 Author Report Share Posted April 26, 2012 guys im having a night mare with her!! Link to post Share on other sites
Moochalargo 0 Posted April 26, 2012 Author Report Share Posted April 26, 2012 Had the head pressure tested cold and hot and its fine!!this makes me think that the block must have a fault somewhere or the new oil cooler i purchased may be a dud!! either way ive got to get more head bolts and another head gasket.im going to try and bypass the oil cooler to eliminate that from the question!do any of you know of a good water treatment? ive had irontight mentioned and also steel seal ive been promissed is amazing!any other ideas as i really need the car working now! its been broken for almost 4 months!!!cheers guys Link to post Share on other sites
Daverse 175 Posted April 26, 2012 Report Share Posted April 26, 2012 sure you installed the oil cooler ok? if you misaligned the seal it could be leaking Link to post Share on other sites
VR6Pete 1,455 Posted April 26, 2012 Report Share Posted April 26, 2012 My money is on the oil-cooler, probably the cheapest and easiest thing to rule out! Link to post Share on other sites
Moochalargo 0 Posted April 26, 2012 Author Report Share Posted April 26, 2012 Yeah ok thanks lads!! Going to get my bolt set and gasket later and for now bypass the cooler!I also need a part if anyone has one? The breather of the head that connects to the plastic air intake pipe has broken after being moved around so much!! Anyone got one? Cheers Link to post Share on other sites
ski 0 Posted April 29, 2012 Report Share Posted April 29, 2012 would say oil cooler aswell, or you might have a problem with your block :/. Link to post Share on other sites
Moochalargo 0 Posted May 13, 2012 Author Report Share Posted May 13, 2012 Rebuilt now. Head tested and not crackedOil cooler bypassed. Oil still getting in to water. What can I do now? I'm out of z job at moment and this is thrashing my money! Really can't keep wasting what little money I am earning? Link to post Share on other sites
Moochalargo 0 Posted May 20, 2012 Author Report Share Posted May 20, 2012 Ok this engine is dead!! Case must be cracked as loosing all oil in to water and it's now bursting hoses lolI've been and got another engine which I believe is ok but this engine is slightly different!! The cam cover is aluminium not plastic like mine. Also the exhaust manifolds have a metal hose that connects them and then seems to go to somewhere??? My car does not have this!!! What is it? Link to post Share on other sites
VR6Pete 1,455 Posted May 20, 2012 Report Share Posted May 20, 2012 Yeah earlier VR's had alloy cam covers, later replaced with plastic as they are quiter. Not sure about your exhaust manifold? Any pics? Link to post Share on other sites
cabrioman 6 Posted May 20, 2012 Report Share Posted May 20, 2012 the metal pipe on the exhaust fanny mould is for the EGR but as far as i know no UK spec cars have the EGR system fitted so it should just link from one side of the exhaust to the other .... Link to post Share on other sites
