Dubvr 0 Posted November 24, 2010 Report Share Posted November 24, 2010 Hi guys wanting to no the best way to reduce the mount sizes to fit the vr6 in the mk2 golf bay ? cheers *-) Link to post Share on other sites
CALICO 130 Posted November 25, 2010 Report Share Posted November 25, 2010 what mount sizes ?? Link to post Share on other sites
Dubvr 0 Posted November 25, 2010 Author Report Share Posted November 25, 2010 its the widetrack set up but been told its gt to be lowered in thy? would this be true. Link to post Share on other sites
VR6Pete 1,455 Posted November 25, 2010 Report Share Posted November 25, 2010 Didn't have any issues with my mk2 on widetrack and was running a scrick too. Although was running Vibratechnics mounts. marktwovr6t 1 Link to post Share on other sites
Dubvr 0 Posted November 26, 2010 Author Report Share Posted November 26, 2010 Ohh thats a big relief then was reading up on somebodys vr6 conversion in his mk2 and he says you have to lower the engine in the bay to clear the bonnet. Thats a big help tho VR6pete Link to post Share on other sites
toadboy 0 Posted December 18, 2010 Report Share Posted December 18, 2010 HI MATE IVE RECENTLY FITTED A VR6 INTO MY MK2 AND YOU HAVE 2 CUT THE REAR ENGINE MOUNT DOWN 15MM 2 CLEAR THE BONNET HOPE THIS HELPS Link to post Share on other sites
GEPY 0 Posted February 8, 2011 Report Share Posted February 8, 2011 my mk2 vr fitted by some one else but fits in nice as long as u use vr running gear ie subframe. Link to post Share on other sites
Smit. 0 Posted March 8, 2011 Report Share Posted March 8, 2011 i didnt realise you had to lower the engine for clearance! I will remember this over the next coming weeks!! Link to post Share on other sites
taz6673 0 Posted May 26, 2011 Report Share Posted May 26, 2011 I had to get my vibratechnics rear engine mount machined down by 25mm to get engine sit straight and clear bonnet. Was miles off at standard height even using vr subframe n rado crossmember. Link to post Share on other sites
bentheboffin 1 Posted May 28, 2011 Report Share Posted May 28, 2011 the only reason you cut the rear mount is so that the engine sits level.if you are planning on slamming your car then there is detailed guid on mk2vr6 on how to raise your engine with the other 2 mounts using hockey pucks but leave the rear engine mount alone Link to post Share on other sites
Vw_owner 1 Posted July 1, 2011 Report Share Posted July 1, 2011 to put a vr6 in a mk2 is it fairly straight forward with the mountings? Link to post Share on other sites
michael5556 247 Posted July 1, 2011 Report Share Posted July 1, 2011 Yeah I have just finished mine this week. I used mk3 subframe,power steering, hubs, brakes, I used the mk2 front cross member with a special mount off eBay for £40. Just make sure you hammer the chassis leg for clearance of the pulley. Link to post Share on other sites
ski 0 Posted April 29, 2012 Report Share Posted April 29, 2012 The rear mount does need to lowered. Link to post Share on other sites
JamesSvr6 1 Posted September 7, 2012 Report Share Posted September 7, 2012 I used a corrado vr6 subframe, mk3 engine with standard inlet and I took 15-20mm off the rear engine mount because it was just touching the bonnet. Seems strange that some people need to and others don't, must just depend on the parts you are using. Engine mounts compress a bit over time (different brands may be slightly different heights and material too) so this will obviously effect how close the engine sits to the bonnet.Remember also to modify chassis leg where the crank pulley is. If you don't it causes the crank pulley to rub on hard left handers. Link to post Share on other sites
Database14 0 Posted November 12, 2012 Report Share Posted November 12, 2012 Completed my mk2 vr6 swap recently, never touched any of the mounts and no issues with clearance. Wonder what all the fuss is about seriously. Used Jetta MK3 k-frame and passat vr6 motor mounts (all 3) Link to post Share on other sites
