UnitedMotorsport 55 Posted November 8, 2010 Report Share Posted November 8, 2010 Also dont use silicon sealant on the inlet, if any of it gets into the engine, it will wreck your lambda probe. You shouldn't need to use any other than OE gaskets. Link to post Share on other sites
*P3nfold* 0 Posted November 8, 2010 Author Report Share Posted November 8, 2010 The silicon sealant was on it when I bought it. Its been on for a while. I have contact G-Werks for a complete gasket kit for the Shrick. Is the kit OEM if so I can get from TPS?What about the gasket between the tube thing to the manifold which is currently connected with silicone. I am sure that's not on the standard one.United can you help? Link to post Share on other sites
UnitedMotorsport 55 Posted November 8, 2010 Report Share Posted November 8, 2010 You need to define "Tube thing" Link to post Share on other sites
*P3nfold* 0 Posted November 8, 2010 Author Report Share Posted November 8, 2010 The 6 looking tubes at the front! Link to post Share on other sites
CALICO 130 Posted November 8, 2010 Report Share Posted November 8, 2010 the six ports on the front of the schrick where it joins by the flap was siliconed 6 months ago only a small smear as it didnt come with a gasket and not supplied when i bought the rest of the parts for the schrick Link to post Share on other sites
jason2875 0 Posted November 8, 2010 Report Share Posted November 8, 2010 had a simler prob when i fitted my shrick turned out there was a crack in the manifold gasket,soon as i replaced it it cured my problems Link to post Share on other sites
*P3nfold* 0 Posted November 8, 2010 Author Report Share Posted November 8, 2010 Thanks Jason, I have a spare in the shed, I will give it a go. Link to post Share on other sites
*P3nfold* 0 Posted November 9, 2010 Author Report Share Posted November 9, 2010 This is killing me, I still have the issue and its getting worse. Link to post Share on other sites
p0u1 14 Posted November 9, 2010 Report Share Posted November 9, 2010 have you gaped the spark plug to the right gap, also did you let the TB calibrate affter you did the work, and like craggy said are you sure you didnt nick one of the ht leads when you installed the head, i really dont see how a gasket on the TB or inlet manifod could cause it to run very poorly but iv never had that problem so i dont know Link to post Share on other sites
VR6Pete 1,455 Posted November 9, 2010 Report Share Posted November 9, 2010 have you gaped the spark plug to the right gap' date=' also did you let the TB calibrate affter you did the work, and like craggy said are you sure you didnt nick one of the ht leads when you installed the head, i really dont see how a gasket on the TB or inlet manifod could cause it to run very poorly but iv never had that problem so i dont know [/quote']I can - I had a split in my Schick gasket at the front of the schrick and it ran like a sack of spanners.... Pete Link to post Share on other sites
*P3nfold* 0 Posted November 9, 2010 Author Report Share Posted November 9, 2010 Hi Admin which gasket at the front? Does anyone know if you can use an OEM gasket? Link to post Share on other sites
craggsy 91 Posted November 9, 2010 Report Share Posted November 9, 2010 Schrick only I beleive, sometimes they will send you one if you contact em direct Link to post Share on other sites
*P3nfold* 0 Posted November 9, 2010 Author Report Share Posted November 9, 2010 Damn I am a broken man, the Schrick is off tonight pending all new gaskets. Link to post Share on other sites
VR6Pete 1,455 Posted November 9, 2010 Report Share Posted November 9, 2010 Yeah schrick special gaskets. I think I got mine from Amber performance on the advice of Vince @ stealth - don't quote me though. Although I did make one out of some thick cardboard while I waited for my schrick gasket to come :-) Link to post Share on other sites
CALICO 130 Posted November 9, 2010 Report Share Posted November 9, 2010 you can get gasket paper but i would have thought it would be the lower of the 2 or throttle body gasket to be honest as it didnt leak on mine can get gasket paper on ebay other 2 gaskets if not expensive get from VW saves petrol driving to tps Link to post Share on other sites
CALICO 130 Posted November 9, 2010 Report Share Posted November 9, 2010 im off thursday afternoon if you need ahand or wanna borrow my car before then Link to post Share on other sites
*P3nfold* 0 Posted November 9, 2010 Author Report Share Posted November 9, 2010 Thanks Guys. For your support and advice.I have a plan put on the new oem throttle body and lower manifold gasket and try again if this fails.Then Schrick off and back to standard pending on Schrick Gaskets and a good clean with polish. Link to post Share on other sites
*P3nfold* 0 Posted November 10, 2010 Author Report Share Posted November 10, 2010 No luck back to standard. I still have the problem Link to post Share on other sites
p0u1 14 Posted November 10, 2010 Report Share Posted November 10, 2010 ht leads???? Link to post Share on other sites
DrRich 1 Posted November 10, 2010 Report Share Posted November 10, 2010 Sorry can't help but just want to say keep going. The Schrick turned my car into the VR6 I'd hoped for - couldn't believe the improvement in driveability and mpg. Ok, it's no super/turbocharger but it still put a big smile on my face! Link to post Share on other sites
craggsy 91 Posted November 10, 2010 Report Share Posted November 10, 2010 Martin have you check HT leads like I said a few data ago as it's so easy to trap them under a schrick. I know the state of mine after living under mine for a few months Link to post Share on other sites
VR6Pete 1,455 Posted November 10, 2010 Report Share Posted November 10, 2010 unplug your HT leads one at a time on the coilpack.... if runs worse, then that plug is working ok, but if it stays the same, its narrowed down your problem...also, unplug your MAF, if it runs worse, then it probably is OK, if it runs the same, then its probably got issues.. Link to post Share on other sites
*P3nfold* 0 Posted November 10, 2010 Author Report Share Posted November 10, 2010 Hi Guys, I checked the HT leads and they seem ok. I spoke to Tony and booked some time with him to take a look. I am going to wait a week for all the parts for the schrick to arrive. I got new throttle and manifold gaskets. I will most likely fit the AP suspension in a few weeks and the D90's are coming off to save some money as well.Its not all bad at least I hope if it is then its going to be sell the mods I guess.So no VR for a week. Hey Pete I am looking forward to hearing about yr corrado project. Tony sort of explained to me. Hope it goes well.Oh one other point, I cannot do team south meet this month, I wanted to bring my wheels but its going to have to wait. Link to post Share on other sites
oldmandon 1 Posted November 10, 2010 Report Share Posted November 10, 2010 Oh one other point' date=' I cannot do team south meet this month, I wanted to bring my wheels but its going to have to wait.[/quote']Come in a different vehicle...names to faces etc...more the merrier...... Link to post Share on other sites
*P3nfold* 0 Posted November 10, 2010 Author Report Share Posted November 10, 2010 Oh one other point' date=' I cannot do team south meet this month, I wanted to bring my wheels but its going to have to wait.[/quote']Come in a different vehicle...names to faces etc...more the merrier......I might mate depends on what the wife has planned with my girls. I will be at the Christmas meet hopefully! Link to post Share on other sites
