apparently the stuff to use is Redline MT90
highly reccomended from guys on the corrado forum, will use this myself when i get round to changing it.
hope this helps mate. presume it wont be to hard to find, usual google search should do the job...
stuart
Changed mine when I bought the car - Found there was very little in it - Which was really bad !! especially seeing as it had had it's 40K service 3k prior to me buying it - they are supposed to check the gear box level on that one!!!
Did my research and bought 75W90
Demon Tweeks product code for the MT90 is REDMT90Q - you need 2 of these (US quart each)
I also added some ZX1 - addative (not like those shitty PTFE based addatives that gum everything up)
drain plug is on bottom of diff.
fill plug is on the front of the gearbox about half way up.
17mm allen key...but you can use a wheel bolt and a spanner. i'd remove the fill plug first in case it wont come out, as if you'd already drained it you'd be screwed. you'll need a long tube and funnel to get it in by the way, its fiddly to get to...make sure the car is level when you fill it as well, and fill it till it starts to come out the fill plug.
