Happy harry 0 Posted July 21, 2010 Report Share Posted July 21, 2010 my mate was telling me i should geta bigger throttle body to help breathing release a bit of power is this possible? can i fit a corrado throttle body??its a 97 vr6 btw so its obdII?any little cheap mods i can do to release a bit of power? ive got an induction kit, 6 branch manifold and de-cat what else can i do??? Link to post Share on other sites
dman78 1 Posted July 21, 2010 Report Share Posted July 21, 2010 im sure i've read on here that it wont fit as it is obd1 but i might be mistaken Link to post Share on other sites
Happy harry 0 Posted July 21, 2010 Author Report Share Posted July 21, 2010 im sure i've read on here that it wont fit as it is obd1 but i might be mistakeni thought that aswell tbh but this guy really knows what he's talking about so there must be some kind of throttle body upgrade??i'll ask him! lol Link to post Share on other sites
dman78 1 Posted July 21, 2010 Report Share Posted July 21, 2010 pls do i would be interested lol Link to post Share on other sites
Rikki 2 Posted July 21, 2010 Report Share Posted July 21, 2010 Rado wont fit obd2. You can port and polish it but you lose torque and dont really gain any! Link to post Share on other sites
FishWick 21 Posted July 21, 2010 Report Share Posted July 21, 2010 I wouldn't mess with OBD2 throttle bodies. They are £350 from VW if you mess it up! You can't enlarge the throttle plate either, which is where the gains come from. Polishing alone does nothing as the throttle hole is still the same size.OBD2 has servo motor idle control, so none of the OBD1 throttles will fit (different stud pattern) or work with the ECU.The head is the biggest restriction. Look at cams and bigger valves if you can afford it. There are no cheap tweaks for the VR sadly....If you can get a Corrado G60 gearbox for pennies and know a mate who can build transmissions, fit the G60's final drive to your VR box. Honestly, that alone makes more difference to accceleration than cams, throttles and breathing work put together. Link to post Share on other sites
Happy harry 0 Posted July 21, 2010 Author Report Share Posted July 21, 2010 I wouldn't mess with OBD2 throttle bodies. They are £350 from VW if you mess it up! You can't enlarge the throttle plate either' date=' which is where the gains come from. Polishing alone does nothing as the throttle hole is still the same size.OBD2 has servo motor idle control, so none of the OBD1 throttles will fit (different stud pattern) or work with the ECU.The head is the biggest restriction. Look at cams and bigger valves if you can afford it. There are no cheap tweaks for the VR sadly....If you can get a Corrado G60 gearbox for pennies and know a mate who can build transmissions, fit the G60's final drive to your VR box. Honestly, that alone makes more difference to accceleration than cams, throttles and breathing work put together.[/quote']thanks for the info! maybe i'll make the best of what ive got then! lolwhat about induction kits whats the owners recommendation??? ive got a shitty universal cone filter atm! Link to post Share on other sites
CALICO 130 Posted July 21, 2010 Report Share Posted July 21, 2010 bmc cda seam to come quite high Link to post Share on other sites
TheMainManRob 0 Posted July 22, 2010 Report Share Posted July 22, 2010 Seconded BMC CDA, Its a big bastard so will need to spend time getting in just right. Link to post Share on other sites
CALICO 130 Posted July 22, 2010 Report Share Posted July 22, 2010 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?373246.0#post_375393 Link to post Share on other sites
