Okay just fixed my VR6 yet again - oil leek this time and since then my temp display on the dash never gets above 70 degrees. Was sitting at half way temp before i fixed the oil leek.
Heaters in my motor have never been great but they are bloody crap now. When i bought the VR the guy had just done the themrostat and i've replaced everything else, head gasket, chains, temp sensor the whole lot.
Was thinking water pump? any other idea's? Anyone else had this problem.
check aux water pump is working
Would that make the gauge low???? as i think mine isnt working and my gauge doesnt read in the middle like it used to.....although its the correcxt temp on vagcom so prob just the sensor in the thermo housing!
i have the same problem. and here hungary many of my friends have also. i've talked many mechanist and they said if the oil temp is ok, everything is ok. We don't have sensor problems, it's just a mysterious problem, and i don't think it's a big problem.Perhaps it's a bit aembrassing, but i could not do anything to disclaim that problem, but ihad tried a lot. :)
