VR6_Jim 0 Posted December 9, 2009 Report Share Posted December 9, 2009 Was drivin home tonight smelt a syrup sort of smell and **** loads of steam came out of the dash. Does this sound like heater matrix or burst pipe. Link to post Share on other sites
russj249 2 Posted December 9, 2009 Report Share Posted December 9, 2009 are either of the footwell's wet?? That's going to be the main one, if it's steaming from dash it's obviously leaking somewhere inside the car and dripping somewhere, So just check the carpets first.and does the front window steam up when you out the heater on as though you are de-misting it?Does sound very much like heater matrix though. Never done one on the VR6 before but I imagine it's a dash out jobby. Link to post Share on other sites
VR6_Jim 0 Posted December 9, 2009 Author Report Share Posted December 9, 2009 Yeah drivers footwell is soaked aswell as my legs and feet cos all the water pi*sed out the bottom of the dash and steam came out of the steering colum and everywere else. Hopeing it's just a pipe burst. But it's never that easy is it. Lol. Link to post Share on other sites
VR6_Jim 0 Posted December 10, 2009 Author Report Share Posted December 10, 2009 Does any 1 think there's a chance that it could b a pipe gone as it's mainly on the drivers. And the drivers footwell has been wet for a couple of weeks. Cheers jimCheers jim Link to post Share on other sites
VR6_Jim 0 Posted December 11, 2009 Author Report Share Posted December 11, 2009 Bump Link to post Share on other sites
VR6_Jim 0 Posted December 17, 2009 Author Report Share Posted December 17, 2009 Bump Link to post Share on other sites
Mk1 Vr6 james 103 Posted December 17, 2009 Report Share Posted December 17, 2009 Defo sounds like the matrix m8! i have just this minute finished fitting my new one. Link to post Share on other sites
VR6Nat 9 Posted December 17, 2009 Report Share Posted December 17, 2009 Yeah, it could be a burst pipe, but could also be the heater matrix, this is a pain of a job because you do have to take the dash out... but then if it is a burst pipe this could point to a head gasket problem as that can cause a build up of pressure which in turn would burst the pipe.... :( Link to post Share on other sites
VR6_Jim 0 Posted December 17, 2009 Author Report Share Posted December 17, 2009 Cheers guys. The temp gauge did go quite high bout 5 mins before the car filled with steam and water. Does this sugest anything else to any 1 like head gasket cos I don't like the sound of that. Cheers peepsjim Link to post Share on other sites
cabrioman 6 Posted December 17, 2009 Report Share Posted December 17, 2009 sounds like heater matrix mate .... get it done and if ur still worrie about the head gasket get a sniffer check done ... that will tell u but id put money on ur matrix goin pop .... can bypass it by joining the two pipes goin into the bulk head but wont have heat in the car but also wont have any more water in the footwells Link to post Share on other sites
VR6_Jim 0 Posted December 17, 2009 Author Report Share Posted December 17, 2009 Cheers mate already joined the pipes so that's cool. Any 1 got any idea how much it would cost to get the matrix done cos I don't fancy doin it in this weather.Cheers jim Link to post Share on other sites
cabrioman 6 Posted December 17, 2009 Report Share Posted December 17, 2009 depends where u go and who u talk to .... about a 3-4 hour job Link to post Share on other sites
VR6_Jim 0 Posted December 17, 2009 Author Report Share Posted December 17, 2009 I was told it's bout 8-10 hour jobjim Link to post Share on other sites
Mk1 Vr6 james 103 Posted December 17, 2009 Report Share Posted December 17, 2009 www.eurocarparts.com cost me £30 for the matrix came next day. Fitted it this morning did it in 1h40m have 2 take the dash out! Link to post Share on other sites
VR6Pete 1,455 Posted December 18, 2009 Report Share Posted December 18, 2009 Cant see it being a pipe, as the pipes terminate onto the matrix in the engine bay. this screams heater matrix i'm afriad! got one that needs doing on my corrado too Link to post Share on other sites
cabrioman 6 Posted December 18, 2009 Report Share Posted December 18, 2009 I was told it's bout 8-10 hour jobjimblimy who quoted u that ???? Link to post Share on other sites
VR6_Jim 0 Posted January 2, 2010 Author Report Share Posted January 2, 2010 Cheers for all ur help guys just fixed the matrix thismorning got it for £23 took bout 3 and half hours. Cheers.Jim Link to post Share on other sites
ex911driver 0 Posted January 3, 2010 Report Share Posted January 3, 2010 i just done heater matrix on my other golf , its a bittch of a job, had to take dash out ,steering wheel off and stalks , but you dont need to remove metal brace that goes across car as you can lift up high enough when you remove 4 bolts from door shuts, and 2 bolts behind steering column . to drop all heater box out so is enogh room to lift matrix out , there are 3 bolts in engine bay holding heater in place , 2 you can see 3rd is under heat shielding , also to remove dash you need to remove 2 bolts under windscreen scuttle , there is 1 on right you can get too , but on drivers side you need to remove wiper arms and take motor out as bolt is behind . Link to post Share on other sites
