heater matrix and dash controls
has anyonr got a exploded diagram
i fitted a new matrix , but i get no heat, i believe its the control box , but wana check my heater cables , just incase. pipes are hot going into and out of matrix, so i reckon im getting water, but no heat even after a hour of running.
thanks jim
  • 2 months later...
Hi Gents
Did you manage to solve this? as i have the same problem, had a new matrix fitted. (I do not know if heater worked before new matrix as the matrix was bypassed when I aquired the car) No coolant leaks, car runs at constant temperature (90) both pipes to/from matrix hot, but no heater??
Any help would be appreciated, fed up with my daughter constantly moaning about being cold!!
i fitted a new matrix ' date=' but i get no heat, i believe its the control box , but wana check my heater cables , just incase. pipes are hot going into and out of matrix, so i reckon im getting water, but no heat even after a hour of running.
thanks jim
Hi,
Can anyone help, please?
I have the same problem!!
