apd 0 Posted December 3, 2004 Report Share Posted December 3, 2004 decided to inspect the condition of hall sender this morning[behind coilpack,in the side of the block].gunked with oil,cleaned it with elect. contact spray and re-inserted.went for a drive-f***************ck me.what a difference it made.now pull/revs like it is chipped.only cleaned it to see if it improved the 'dead' acceleration 1-2k revs in any gear and that little bit of kick back i got when feathering the throttle.my faith in the vr has been re-installed,very pleased.hope this throws light onto other members problems. !amazed !amazed Link to post Share on other sites
bazz780 0 Posted December 3, 2004 Report Share Posted December 3, 2004 oh i want to do this too!!please tell me details of how i can share the same pleasure, step by step would be niceplease please please Link to post Share on other sites
acf8181 0 Posted December 3, 2004 Report Share Posted December 3, 2004 yeah, the gunk wouldn't have helped.i know what its like to have a hall sender problem...it takes at leats 20-30bhp. Link to post Share on other sites
apd 0 Posted December 3, 2004 Author Report Share Posted December 3, 2004 baz780:disconnect battery + terminal for safety.remove leads from coilpack.take off the leads shrouding[star bolts x3].remove the coilpack from the side of the block[allen bolts x4].unclip the the coilpack plug in.the hall sender will be behind the coilpack.unplug the hall sender and remove x1 allen bolt.withdraw the sensor carefully and clean any oil deposits/gunk from it[elect. contact cleaner].refit in reverse.then this is the best bit........GO FOR A DRIVE. Link to post Share on other sites
bazz780 0 Posted December 3, 2004 Report Share Posted December 3, 2004 kewl will do this asap, where do you get the elec cont cleaner from? wd40? Link to post Share on other sites
binliner 0 Posted December 3, 2004 Report Share Posted December 3, 2004 get it from Halfords or the like Link to post Share on other sites
bazz780 0 Posted December 5, 2004 Report Share Posted December 5, 2004 kewl got the cleaner from maplins, 1.99 spray, now just got to find time to clean and play lol will let you all know Link to post Share on other sites
binliner 0 Posted December 5, 2004 Report Share Posted December 5, 2004 Is the hall sender the metal cylindrical shape bit about the size of a cork? Link to post Share on other sites
acf8181 0 Posted December 6, 2004 Report Share Posted December 6, 2004 sort of yeah Link to post Share on other sites
binliner 0 Posted December 6, 2004 Report Share Posted December 6, 2004 you dont need to remove the coilpack to remove it Link to post Share on other sites
Nerih 0 Posted December 6, 2004 Report Share Posted December 6, 2004 hehe, i think yer coilpack fell off somewhere m8 . What are the typical symptoms of a dirty hall sender? poor power at low rpms? Link to post Share on other sites
bazz780 0 Posted December 6, 2004 Report Share Posted December 6, 2004 how do i get to the hall sender then? how do i identify Link to post Share on other sites
acf8181 0 Posted December 6, 2004 Report Share Posted December 6, 2004 you don't have to remove the coilpack, but it'll be easier to get to if you do.its right near the coilpack, and goes into the upper cam chain housing, held by one 5mm allen key bolt (be careful, they round easily).symptoms when mine screwed up were serious loss of power, and very lumpy running. though it felt ok at very low rpms. Link to post Share on other sites
bazz780 0 Posted December 6, 2004 Report Share Posted December 6, 2004 apd would that be the same for a 95 face lift model? still behind the coil pack? cheers Link to post Share on other sites
bazz780 0 Posted December 6, 2004 Report Share Posted December 6, 2004 ?? Link to post Share on other sites
acf8181 0 Posted December 6, 2004 Report Share Posted December 6, 2004 yep, its in same place on all vr6's (though on '92 cars it'll be behind dizzy, not coilpack) Link to post Share on other sites
apd 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 mines a 94m with new coilpack.had intermittent flat acceleration 1-3k and a bit of 'kick back' when on/off throttle any revs.had it on vag com-crank position sensor fault or hall sender G40 negative to earth.it is as behind the c/pack as ACF explains.after i cleaned it it's been like ULTRA responsive in any gear@ any revs.let me rephrase that-IT'S FUCKING ACE!!!!!! Link to post Share on other sites
binliner 0 Posted December 6, 2004 Report Share Posted December 6, 2004 I checked mine... clean as a whistle Link to post Share on other sites
apd 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 BAZ780;after you take the single allen bolt out.work the hall sender out slowly.you'll be looking at a small stubby cylindrical sensor with 2 'O' rings around it.i cleaned all oil/gunk deposits off it until spotless.re-inserted and refitted everything else back in place.its now a different car.hope you have the same success as me BAZ780! Link to post Share on other sites
Eat this 2 Posted December 6, 2004 Report Share Posted December 6, 2004 I checked mine... clean as a whistlenow theres a shock lol didnt u polish it hehe Link to post Share on other sites
bazz780 0 Posted December 6, 2004 Report Share Posted December 6, 2004 lol, i cant wait!!! y am i on the 6pm finish shifts aRGHHHH Link to post Share on other sites
acf8181 0 Posted December 7, 2004 Report Share Posted December 7, 2004 I checked mine... clean as a whistlei think that will be the most common result. mine was not gunked up, and i'd have thought it was rare. Link to post Share on other sites
Nerih 0 Posted December 7, 2004 Report Share Posted December 7, 2004 did mine today, its got not got any dirt in it. Link to post Share on other sites
binliner 0 Posted December 7, 2004 Report Share Posted December 7, 2004 I was hoping mine would be filthy! Link to post Share on other sites
bazz780 0 Posted December 7, 2004 Report Share Posted December 7, 2004 how much are they to replace? any ideas? Link to post Share on other sites
