andy 0 Posted December 7, 2004 Report Share Posted December 7, 2004 £40 ish from the stealer iirc. Link to post Share on other sites
bazz780 0 Posted December 12, 2004 Report Share Posted December 12, 2004 hi, just cleaned the sensor, it wasnt totally gunked in oil but it did have some dry oil marks and oil on it,cleaned it off re-assembled and took it for a spin, BLOOOODYYYY HELLLLLLLLLLLLLLLLLLLLLL it was soooo fast and responsive, if i give a bit in first until 200 revs then just pound it the car just takes off!!!i aint had a good clear run yet but seems to have done the trick, might replace it when i can financially reason it,many thanks!!!!! well worth the hassle!!! Link to post Share on other sites
bazz780 0 Posted December 12, 2004 Report Share Posted December 12, 2004 ONE QUESTION:i know there is a rubber seal (ring) at the top of the cylinder, where is the plastic ring supposed to be located on the sensor? is that just after the rubber seal or ....??if i wernt careful enough when taking it out, it would have slipped off and dropped in to the engine, Link to post Share on other sites
acf8181 0 Posted December 12, 2004 Report Share Posted December 12, 2004 sorry bazz id ont have a clue what bit you're talking about...my sensor was all one piece.pics? Link to post Share on other sites
bazz780 0 Posted December 12, 2004 Report Share Posted December 12, 2004 it is one piece, there is a rubber ring right on top of the shaft near the holder bit, and there was a plastic ring that came out with the sensor too- im assuming this would have been located on the top of the shaft as well (nearest the coil pack) Link to post Share on other sites
acf8181 0 Posted December 13, 2004 Report Share Posted December 13, 2004 do you mean you took the whole top timing chain cover off? Link to post Share on other sites
bazz780 0 Posted December 13, 2004 Report Share Posted December 13, 2004 no i just took the black casing off, took the one hex bolt off, pulled the sensor out and thats it, anyways, it felt REALLY fast initially but i think its died back down lol, might just change it when i get the chance Link to post Share on other sites
acf8181 0 Posted December 13, 2004 Report Share Posted December 13, 2004 black casing?! does yours have a cover over the sender then? or do you mean the plug leads guide? Link to post Share on other sites
bazz780 0 Posted December 13, 2004 Report Share Posted December 13, 2004 thats the one lol Link to post Share on other sites
trispage 0 Posted December 13, 2004 Report Share Posted December 13, 2004 just got a quote from VW, if you have ODB1 engine the sender is part of the dizzy and will cost £222.95 + VAT. NICE !!!!! Link to post Share on other sites
bazz780 0 Posted December 13, 2004 Report Share Posted December 13, 2004 what???? Link to post Share on other sites
acf8181 0 Posted December 13, 2004 Report Share Posted December 13, 2004 bloody vw getting it wrong again.only '92 cars have dizzy's. '93 on are coilpack. Link to post Share on other sites
trispage 0 Posted December 13, 2004 Report Share Posted December 13, 2004 mine is a 92 motor so i guess i am stuck with a dizzy. Link to post Share on other sites
apd 0 Posted December 14, 2004 Author Report Share Posted December 14, 2004 the hall sender has 2 'O' ring seals around it.one slim and one slightly thicker.ive come to the conclusion mine might have not been plugged in properly/needed a clean.but the results are still the same-FAB! Link to post Share on other sites
Devilfish 0 Posted December 14, 2004 Report Share Posted December 14, 2004 can someone please take a piccie of exactly what im looking for ? i'm a bit of a VW newbie.... Link to post Share on other sites
bazz780 0 Posted December 15, 2004 Report Share Posted December 15, 2004 im still kicking myself for not taking a pick, quite an operation (dont take too long) but its cold lol, i can give you a full detailed step by stpe type up if you want (no pics tho)? lemme knwo ill type one up Link to post Share on other sites
bazz780 0 Posted December 15, 2004 Report Share Posted December 15, 2004 pick? i meant PIC,the two o ring seals, where would they sit on the sensor??? im assuming right at the top? Link to post Share on other sites
