vr69 0 Posted October 2, 2009 Report Share Posted October 2, 2009 rite iv read all i can find on here as i dont like to waste peoples time.i have found a selection of turbos that look as if thay are up to the job but not 100% sure.garrettTB0303Blitz KKK K27 Hybrd Turbo Ford Sierra Cosworth Garrett t3 turbo chargerany help would be much appreacheted Link to post Share on other sites
MaidenVR6 26 Posted October 3, 2009 Report Share Posted October 3, 2009 rite iv read all i can find on here as i dont like to waste peoples time.i have found a selection of turbos that look as if thay are up to the job but not 100% sure.garrettTB0303Blitz KKK K27 Hybrd Turbo Ford Sierra Cosworth Garrett t3 turbo chargerany help would be much appreachetedForget all off them. They are to small.A VR6 needs bigger exhaust housings.Typical T3 0.81 Link to post Share on other sites
golfrabbit33 0 Posted October 3, 2009 Report Share Posted October 3, 2009 t3 0.83 garrett gt3076r is my set up. good to 500hp Link to post Share on other sites
matty.vrt 120 Posted October 3, 2009 Report Share Posted October 3, 2009 I thort all the audi s2 boys use k27 turbos and get 500-550 bhp Link to post Share on other sites
CALICO 130 Posted October 4, 2009 Report Share Posted October 4, 2009 S2 are 5 cylinders and not 500bhp standard Link to post Share on other sites
matty.vrt 120 Posted October 6, 2009 Report Share Posted October 6, 2009 standard s2's have k24 rs2 have k26 and they do a k26-27 hybrid good for 460 bhp so yeh k27 will make boost early but by no means too small Link to post Share on other sites
CALICO 130 Posted October 6, 2009 Report Share Posted October 6, 2009 Low boost early no intercooler proper sleeper init Link to post Share on other sites
MaidenVR6 26 Posted October 9, 2009 Report Share Posted October 9, 2009 S2/RS2 have 2.2 litre engines.A VR6 have atleast 2.8 litre and 1 cylinder more. So you need a little bigger turbo than a stock 2.2T 5in engine. Link to post Share on other sites
vr69 0 Posted October 11, 2009 Author Report Share Posted October 11, 2009 garrett gt32 turbo?????this is the info i have found, would it be sutable????This is largest Garrett GT32 available, The GT3271.This turbo is capable of 400+ HP. Brand new Garrett GT32 (GT3271) turbo assembly. Available in either Internal or External wastegate configurations, your choice. The internal wastegated unit comes with a adjustable actuator, hose, boost reference fitting, etc. Both wastegate configurations have a T3 divided inlet turbine housing with a 6_bolt exit.Aslo available is the .69 A/R Intenal wastegate exhaust housing. ($110.00 extra, please email if you want this housing)Specify Internal or External wastegate.-Compressor: 71.0mm w/ 52 trim-Turbine: 73 Trim, .78 A/R (T3 divided inlet w/ 6_bolt exit)Note:: ALL of our Garrett GT turbochargers come Fully Balanced from the factory & have the Manufacturers Warranty.The Garrett GT series line up is much more efficient then the old "T" technology & provides spool-up 1000's of RPMs quicker. The GT series turbos are stronger, more reliable, have less shaft movement, better flow dynamics, less lag....the list goes on. Simply put, GT blows T away!! Link to post Share on other sites
UnitedMotorsport 55 Posted October 11, 2009 Report Share Posted October 11, 2009 The kind of turbo you need is a T3/T4 based one.Depending on how you like the turbo to spool, either a 0.63 or 0.82 AR turbine housing.Or if you want to spend a little more use a GT35R. Link to post Share on other sites
J5KE F 0 Posted October 11, 2009 Report Share Posted October 11, 2009 as C2 said.. we have a t3/t4 unit and pushin approx 290 @ 13 psi, but could easily be doubled if engine hardware was to be upgraded.thats on a 140k stock lump but spaced gasket.. Link to post Share on other sites
matty.vrt 120 Posted October 11, 2009 Report Share Posted October 11, 2009 gt3582r is where its at if its good enough for kevhaywire its good enough for any one.lol Link to post Share on other sites
FishWick 21 Posted October 12, 2009 Report Share Posted October 12, 2009 Yeah the 35R is a nice unit :-). It has a very good top end / midrange compromise imo. Link to post Share on other sites
MaidenVR6 26 Posted November 3, 2009 Report Share Posted November 3, 2009 But the Garrett GT35R needs to be a old turbo? Its been around for years. I think its turbo's in the same range, that kicks the Garretts ass pretty good. Like the new Precision billett series. I would go for one off them, if I needed a new one now. Link to post Share on other sites
FishWick 21 Posted November 4, 2009 Report Share Posted November 4, 2009 Why does that matter? The T3/T04E has been around even longer and is still popular and works well.Got any dyno plots showing a precision the same size and trim as a GT35 kicking it's ass? Link to post Share on other sites
MaidenVR6 26 Posted November 4, 2009 Report Share Posted November 4, 2009 USP's 12V S4 did very well with it. And they love it. Mickael aka VR6GT42RS told me the same. That the Precision is much more effective and 30% lighter turbin wheel.Im not saying that GT35R isnt any good. I have one my self, and love it.And a T3/T4 standard journal bearing turbo's is another price range than both GT35R and billett Precision. Link to post Share on other sites
FishWick 21 Posted November 5, 2009 Report Share Posted November 5, 2009 Cool. Do you mean the Precision 6265? Looks a nice turbo. Do they use Garrett CHRAs and make their own compressor wheel and housings then? Link to post Share on other sites
MaidenVR6 26 Posted November 5, 2009 Report Share Posted November 5, 2009 As far as I have seen, its basiclly a Garrett GT35R, but with better/lighter compressor wheel. Im not sure if the housing is diffrent.Mickael said it was the ultimate VR6 and R32 turbo. That said, the 35R with either 0.82 or 1.06 is very good. I love when I start my car, and let it idle and when I stop it 10 seconds after I can hear the turbo spin for a good while:) I didnt hear that on my old T04S. Wich did 554 crank hp on a Vauxhall Calibra after I sold it:) And lasted for two weeks, hahahaha... Link to post Share on other sites
golfrabbit33 0 Posted March 28, 2010 Report Share Posted March 28, 2010 Yeah the 35R is a nice unit :-). It has a very good top end / midrange compromise imo. glad thats the one i just upgraded to then / 1.06 housing Link to post Share on other sites
