VR6Pete 1,455 Posted December 14, 2014 Author Report Share Posted December 14, 2014 Cheers guys! The time is approaching. Hopefully after my trip I'd have hit the 2k mark on the new lump. Roll on getting it mapped up in the new year. Can't wait give it beans. Will post another vid when I can blip it more Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6Pete 1,455 Posted August 18, 2015 Author Report Share Posted August 18, 2015 Stage 2 begins updates to follow! c00k and bennyk 2 Link to post Share on other sites
VR6Pete 1,455 Posted August 18, 2015 Author Report Share Posted August 18, 2015 Soooo then guys. Been a while since my last update. Engine is now run in ( yay ) and feels really strong on the road. Passed MOT last month without issue and was planning take on holiday to Cornwall. After giving it a once over, I noticed the water pump bearing had gone (great!) so replaced that and I thought we were good to go!Or so I thought! Set off at 4am and drove 100 yards before it broke down. Lovely! Clifford alarm decided to immobilise the car which was great! Couldn't get it going properly and managed to limp it back home and pack my other car. 2 weeks later I got back home and Cabbs came down mine help strip the alarm out. At this point I had lost confidence and decided best cause of action, and given it was VWNW the next day of course! Removing the alarm was a doddle and a couple hours labour (cheers Carl!)So I spent a good 7 hours going over the car with Carl's DA make it look swish again for the show. Hopefully you will agree it came up well ! Was a great day at VWNW and the the severe lack of sleep was worth it seeing it on the club stand! D11PS, daveyboy and Bealieboy 3 Link to post Share on other sites
VR6Pete 1,455 Posted August 18, 2015 Author Report Share Posted August 18, 2015 And moving up swiftly to stage 2! Boost!Picked up a Vortech V1 cheap as chips with dual idler setup. Was missing a few bits from the kit such as idler pulley spacers, longer alternator bolts and charger mount spacer. I have knowledge, helpful friends and contacts so no problem!A friend in the USA provided the info I need and a helpful member with a lathe in the UK made up alternator spacers (result)!I removed the case from the charger which is currently down at the polishers getting polished, can't wait see it !Just need to nip to the thread shop pick up 115mm alternator bolts and that's that sorted!The pulley needs replacing but may be able to salvage it! It's a 2.75" pulley so will produce some good amounts of boost. Pulley has some damage but watch this space. So next need to source an air filter and a sumo to tap my return connector into. The need to do a try run so I know what belt length I need and get that ordered and then can proceed with the install once I have made up the oil lines. My setup came with a mapped OBD2 ECUand 380cc injectors. I do want to make up some new pipe work as could look much better in stainless. Will keep thread updated with my progress on installation. Bealieboy, bennyk, D11PS and 1 other 4 Link to post Share on other sites
bennyk 1,238 Posted August 18, 2015 Report Share Posted August 18, 2015 (edited) I've got a spare new belt for the V9 set up if that helps Pete, there was nothing else anywhere near close available off the shelf over here, or even in the states when I looked Edited August 18, 2015 by bennyk VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted August 18, 2015 Author Report Share Posted August 18, 2015 I've got a spare new belt for the V9 set up if that helps Pete, there was nothing else anywhere near close available off the shelf over here, or even in the states when I lookedCheers mate. Once I get it bolted up I'll have an idea of what size I need! Link to post Share on other sites
VR6Pete 1,455 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Spacers arrived today. Happy days. Link to post Share on other sites
VR6Pete 1,455 Posted August 19, 2015 Author Report Share Posted August 19, 2015 I've got a spare new belt for the V9 set up if that helps Pete, there was nothing else anywhere near close available off the shelf over here, or even in the states when I lookedWhat length is the belt mate? Link to post Share on other sites
c00k 435 Posted August 19, 2015 Report Share Posted August 19, 2015 Boost is on it's way! Link to post Share on other sites
bennyk 1,238 Posted August 19, 2015 Report Share Posted August 19, 2015 What length is the belt mate?It's a 6 rib 1429mm long belt from ecs tuning Link to post Share on other sites
VR6Pete 1,455 Posted August 22, 2015 Author Report Share Posted August 22, 2015 It's a 6 rib 1429mm long belt from ecs tuningWill let you know. Not sure what length I actually need yet Link to post Share on other sites
VR6Pete 1,455 Posted August 22, 2015 Author Report Share Posted August 22, 2015 So the scroll is looking good ! Got my spacers now for dual idlers. Next on the list is to sort the other spacer And also waiting on sump to arrive Getting boost intake made up in stainless as mine has seen better days. daveyboy 1 Link to post Share on other sites
VR6Pete 1,455 Posted August 31, 2015 Author Report Share Posted August 31, 2015 Ok. So sump has gone to @dlea to weld the AN fitting D11PS and Bealieboy 2 Link to post Share on other sites
c00k 435 Posted September 1, 2015 Report Share Posted September 1, 2015 (edited) If it bolts where the old tensioner goes? I made some for my supercharger. The outside shape is not really important, It's the holes that are important. Although on mine I roughly followed the shaped of the cylinder head for the out side shape. I made a few different thickness as I was unsure of the spacing. Edited September 1, 2015 by c00k VR6Pete and Bealieboy 2 Link to post Share on other sites
VR6Pete 1,455 Posted September 1, 2015 Author Report Share Posted September 1, 2015 If it bolts where the old tensioner goes? I made some for my supercharger. The outside shape is not really important, It's the holes that are important. Although on mine I roughly followed the shaped of the cylinder head for the out side shape. I made a few different thickness as I was unsure of the spacing. Awesome. Yes it's very similar. I need a 9.44m thick plate. I've made up template pretty close to what should be in the kit. A mate of mine has a laser cutter so should be a neat job Bealieboy, D11PS and VR6Pete 3 Link to post Share on other sites
VR6Pete 1,455 Posted September 5, 2015 Author Report Share Posted September 5, 2015 Ok small update. I had noticed the pulley was slightly damaged upon inspection. The outer rib has somehow rubbed on something and rolled the outer lip inwards. Not to worry. A very helpful person (the same person who made up my dual tensioner spacers infact) made a tool to un-roll it!Before:After:Good as new daveyboy, D11PS and c00k 3 Link to post Share on other sites
c00k 435 Posted September 5, 2015 Report Share Posted September 5, 2015 Looking good dude. If you want it totally mint. Put it in some caustic soda, to removed the anodising, leave it 10-15mins and the anodising will just wipe off, no sanding needed to remove it. Then get it re-anodised, powder coat, or paint it. VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted September 5, 2015 Author Report Share Posted September 5, 2015 Looking good dude. If you want it totally mint. Put it in some caustic soda, to removed the anodising, leave it 10-15mins and the anodising will just wipe off, no sanding needed to remove it. Then get it re-anodised, powder coat, or paint it.Awesome. Yeah that's my aim/plan Paul. There is this place down the road from me http://www.pw-finishing.co.uk so was hoping they would sort it out so it looks swank again. I couldn't find any places that had a 2.75" pulley and that's what it's all mapped to etc... Plus didn't want to spend on getting the only available 2.70" or 2.80" pulley at nearly £90 from over the pond. Link to post Share on other sites
VR6Pete 1,455 Posted September 7, 2015 Author Report Share Posted September 7, 2015 Ok, so a little progress today!Finally finished my final template for the spacer, been a bit short on time recently!Good enough send to my mate with a laser cutter Ok, so a little progress today!Finally finished my final template for the spacer, been a bit short on time recently!I am struggling to get 115xm8 bolts for the alternator. If anyone has any info on where I can get these from id appreciate it Also. I need some hose from the Valve thingy to intake...Anyone got any links to where I can get this from?Cheers!Pete Link to post Share on other sites
c00k 435 Posted September 8, 2015 Report Share Posted September 8, 2015 (edited) If you happy to have Allen key heads http://pages.ebay.com/link/?nav=item.view&alt=web&id=360675642473&globalID=EBAY-GB Buy 120mm and chop off 5mm, or let 5mm hang out of end.Or high tensile, again 120mm, chop 5mm off. http://pages.ebay.com/link/?nav=item.view&alt=web&id=360850401876&globalID=EBAY-GB25mm vacuum hose should work for the recirc valve. http://pages.ebay.com/link/?nav=item.view&alt=web&id=190884940904&globalID=EBAY-GB Edited September 8, 2015 by c00k VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted September 8, 2015 Author Report Share Posted September 8, 2015 If you happy to have Allen key headshttp://pages.ebay.com/link/?nav=item.view&alt=web&id=360675642473&globalID=EBAY-GBBuy 120mm and chop off 5mm, or let 5mm hang out of end.Or high tensile, again 120mm, chop 5mm off.http://pages.ebay.com/link/?nav=item.view&alt=web&id=360850401876&globalID=EBAY-GB25mm vacuum hose should work for the recirc valve.http://pages.ebay.com/link/?nav=item.view&alt=web&id=190884940904&globalID=EBAY-GB cheers I didn't know if the unthreaded bit would foul on the thread if it was longer meaning it doesn't fully thread in. I suppose I will need to take a closer look at this and trail fit it all... RE silicon hoses - I was looking at these http://www.autosiliconehoses.com/silicone-polyester-reinforced-hose-25mm-choose-from-15-colours.html - do you think it would be ok? Next on my hit list is the air filter! I really don't want it hanging to low at the risk of sucking up water.... I have seen this filter that ships with the V3 kit and wondering if any sort of after-market type is available? Link to post Share on other sites
c00k 435 Posted September 8, 2015 Report Share Posted September 8, 2015 (edited) 25mm silicone will be fine, So will 25mm vacuum hose, as it only under boost for a coupe of seconds while the valve opens. Most of the time it's not under much pressure or boost at all. You can also get special parts to add in to your air intake system if wanted, to stop hydro lock. It's an extra intake point, that can open if the air filter gets wet and hydro locks.The bolts should work fine, I need 100mm ones for my set up, and bought high tensile Allen key, same as I sent you. Edited September 8, 2015 by c00k VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted September 8, 2015 Author Report Share Posted September 8, 2015 25mm silicone will be fine, So will 25mm vacuum hose, as it only under boost for a coupe of seconds while the valve opens. Most of the time it's not under much pressure or boost at all. You can also get special parts to add in to your air intake system if wanted, to stop hydro lock. It's an extra intake point, that can open if the air filter gets wet and hydro locks.The bolts should work fine, I need 100mm ones for my set up, and bought high tensile Allen key, same as I sent you.Sound mate. Will get the silicone one ordered up Link to post Share on other sites
VR6Pete 1,455 Posted September 14, 2015 Author Report Share Posted September 14, 2015 So, got part of the intake backBefore (sorry crap photo):After:Looking swish!Also now I know how the belt should be installed for dual idler pulley:This is quite important as I still don't know what length belt I need D11PS and Dave_ciw 2 Link to post Share on other sites
Dave_ciw 507 Posted September 15, 2015 Report Share Posted September 15, 2015 Nice Shoes! Coming along nicely chap... Will we see this running the strip next year? VR6Pete 1 Link to post Share on other sites
