when driving round temp gauge never gets out of the first white section, if however i sit in traffic ( rare where i live!) it will go up to normal and the fan cuts inas it should but as soon as i start moving again it drops straight down, is this normal ? i'm thinking probably not,
[ Edited ]
if its not getting out of the white section i find this unusual but if the guage is reading right it means that the coolent is cold.
mine sits just below 70 and goes up to about 100 when sitting in traffic then back down to just below 70 after been moving for a couple of mins
Yeah my water temp gauge always sits slap bang in the middle after it's been running a few minutes, but I fitted a Neuspeed 160 deg thermostat at the weekend so that might not be the case at the moment. Oil temp is usually around the 90 mark, even in traffic.
so all being well should be ok tommorrow,
[ Edited Tue Nov 23 2004, 02:53PM ]
yes, already thought of that, ;);) hence....
[ Edited Tue Nov 23 2004, 05:18PM ]
D'oh...just edited my reply now it doesn't make sense !!!
[ Edited Tue Nov 23 2004, 05:20PM ]
posted again to make some sense !
after talking to bloke at work about this he said thermostat, so i phoned a vw garage and after explaining what happens, needle barely moves, oil gets to around 80 not especially slowly, heater works fine, he said the sender,so iwent and bought 1, will be fitting it in the morning as not to burn my fingers! and will let you know my findings,
*when i mentioned the oil temp he said depends what oil you use and that the oil coolers are good on vr's
[ Edited Tue Nov 23 2004, 10:24PM ]
my oil temp usually site around 93 but usually becuase of my enthiusiastic driving gets to about 100...and drops off as i sit in traffic.
However i always thought that if the guages were up straight (90 degrees to the horizontal) that that was the ideal coolant temperature. Which is why i never bother with it because its usually always pointing straight up (apart when cold doh :))
**update**
just got car back from having thermostat changed, also needed the housing as they said is was cracked,anyway all is well, temp gauge goes to 90 in traffic and drops slightly when moving and oil goes to 96 ... thanks to all who helped, :)
