Phat VR6 3 Posted December 29, 2008 Report Share Posted December 29, 2008 9:1 for lower boost and drives stronger before turbo kicks in8.5:1 for higher boost.. abit weaker off boast so again depends what your aiming for.. Run 9:1 unless your planning on running high boost but it doesnt really matter Link to post Share on other sites
Kelster 0 Posted December 29, 2008 Report Share Posted December 29, 2008 Phat VR6, what are you calling lower boost <14PSi ? Just curious as compression lowering is my next step. Link to post Share on other sites
Phat VR6 3 Posted December 31, 2008 Report Share Posted December 31, 2008 10- 12 psi should be fine on 9:1.. Not saying you couldn't push it more but personally im going to fit 8.5:1 a ill probaly end up turning it up as much as i can lolHears an interesting thread thats worth a read which helps you work out how much boost you can safly run using VAG.comThe lower the compression the less lightly knock will occur and timing getting pulled ect http://forums.vwvortex.com/zerothread?id=3607415 Link to post Share on other sites
MaidenVR6 26 Posted January 2, 2009 Report Share Posted January 2, 2009 How much will it cost you to put turbo on a 24V engine? How much will the software cost? Have you seen the price's on 24V/R32 turbo parts compared to 12V turbo parts?No doubt the 24V er more efficient than the 12V.But the 12V have been out there for so many years now, that the turbo parts have decent price's.And since you already have a OBD2 engine, go with that. Rebuild it, and have fun. Link to post Share on other sites
Radostormvr6 2 Posted January 2, 2009 Report Share Posted January 2, 2009 10- 12 psi should be fine on 9:1.. Not saying you couldn't push it more but personally im going to fit 8.5:1 a ill probaly end up turning it up as much as i can lolHears an interesting thread thats worth a read which helps you work out how much boost you can safly run using VAG.comThe lower the compression the less lightly knock will occur and timing getting pulled ect http://forums.vwvortex.com/zerothread?id=3607415Im running 9:1 with 15psi and making 401bhp Link to post Share on other sites
FishWick 21 Posted January 5, 2009 Report Share Posted January 5, 2009 10- 12 psi should be fine on 9:1.. Not saying you couldn't push it more but personally im going to fit 8.5:1 a ill probaly end up turning it up as much as i can lol It's also worth remembering the turbo's compressor flow when choosing a target boost pressure. PSI is PSI, regardless of turbo size, but a GT35 running 15psi will be pushing more air in than a GT30 running 15psi. So although 9:1 is probably safe with a GT30 running 12psi, it may not be with a GT35.So I'd always run 8.5:1, or even 8:1 if you're planning on big boost pressures with big CFM turbos. The difference in off boost performance between 10:1 and 8.5:1 is negligable if the engine's setup right :-) Link to post Share on other sites
