harrod7159 0 Posted July 9, 2008 Report Share Posted July 9, 2008 I've searched the forum but cant find anyhting... My clutch has lost all feeling No return when i press the pedal etc. it does just about work but right at the end of its travel right on the floor. I bled the system through and all i'm getting out is fluid and air mixed to look like foam. Not really the desired result. i cant see any obvious leaks or anything, so anyone got any ideas?!thanks.,dave Link to post Share on other sites
Matt W 4 Posted July 9, 2008 Report Share Posted July 9, 2008 Keep bleeding until there is no air? Link to post Share on other sites
richievr 1 Posted July 9, 2008 Report Share Posted July 9, 2008 as it shares the fluid with the brakes i would do a brake/clutch fluid change completely.and as said above keep bleeding the system until there is no air at all in there.i take it you have no leaks anywhere? Link to post Share on other sites
harrod7159 0 Posted July 11, 2008 Author Report Share Posted July 11, 2008 I cant see any leaks, but that doesnt mean there aren't any! Just wondered if there are any known problems with seals on master/slave cylinder or anythjing Link to post Share on other sites
superted23 0 Posted August 5, 2010 Report Share Posted August 5, 2010 did you ever find out what the problem was as i have a similar problem, brakes work fine, i bleed clutch and after a few minutes driving i have nothing once again. when bleeding its like a white foamy mixture. think a seal has gone in cylinder but cant get car to garage to have it checked out Link to post Share on other sites
Jerseyvr6 0 Posted January 31, 2011 Report Share Posted January 31, 2011 im having the same problem i just changed the clutch and it worked fine before the change. but now its alot lighter and its right at the bottom of the pedals travel. did anyone have an answer to this please? Link to post Share on other sites
squid1 0 Posted February 4, 2011 Report Share Posted February 4, 2011 got the same n i no my clutch is gd only changed the g/b a few months ago n there was loads on her..? Link to post Share on other sites
Jerseyvr6 0 Posted March 5, 2011 Report Share Posted March 5, 2011 i have the same problem, fitted a new clutch, then it went really light, so i bled the system, and it got worse, i now have no clutch at all.however, today, i replaced the slave cylinder for a second hand one i had spare, and made a bracket to hold the slave push rod in place, then bled the system rechecked for pressure and repeated until i got a solid pedal. ive left it pressurised over nite, and will update in the morning.apperently its something to do with the difference in pressure of the old clutch plate and the new one :/ Link to post Share on other sites
Jerseyvr6 0 Posted March 9, 2011 Report Share Posted March 9, 2011 ok, so i went back in the morning, still had pressure, removed my bracket, and fitted it to the gearbox, lost all pressure, so re-bled and there were bubbles in it again. so im preetty confused now Link to post Share on other sites
