Geastb 0 Posted September 26, 2004 Report Share Posted September 26, 2004 On wednesday i picked up my car after having new engine fitted - on friday a pipe burst and i lost most of my coolant - the engine oil tempo went up to 150 deg - i fixed the burst pipe and refilled with fresh coolant and engine seems fine (no smoke or funny noises) what damage could i have done tho?Or am i worrying for nothing? Link to post Share on other sites
madmonkee 0 Posted September 26, 2004 Report Share Posted September 26, 2004 well excessive heat like that could have caused the head to warp, also u were lucky for none of the piston to have seized!! Link to post Share on other sites
acf8181 0 Posted September 26, 2004 Report Share Posted September 26, 2004 150...that crazy. why on earth did you keep driving? didn't the flashing red light on the dash make you think you should stop.headgaskets usually die between 110-120.i'll be amazed if you got away without damamging anything. Link to post Share on other sites
Eat this 2 Posted September 26, 2004 Report Share Posted September 26, 2004 how dya know it was at 150 i thought the temp gauge went to 110? Link to post Share on other sites
Geastb 0 Posted September 26, 2004 Author Report Share Posted September 26, 2004 Didn't get a flashing light! i only knew because i used the mfa to check then stopped immediately. Seems ok now tho - will keep an eye on all the levels Link to post Share on other sites
VR6Pete 1,455 Posted September 26, 2004 Report Share Posted September 26, 2004 Id check your sensor on your header tank mate. you will be REALLY lucky if it didnt damage anything. Link to post Share on other sites
Geastb 0 Posted September 26, 2004 Author Report Share Posted September 26, 2004 the 150 deg was oil temp - water went to about 105 -(never went right over to the right anyway) I've just driven about 50 miles with no problems hopfully all ok Link to post Share on other sites
Eat this 2 Posted September 26, 2004 Report Share Posted September 26, 2004 thats not as bad then i thought u meant water temp went to 150 hav u checked oil level Link to post Share on other sites
Geastb 0 Posted September 26, 2004 Author Report Share Posted September 26, 2004 oil level fine - still clean too (if that means anything?) Link to post Share on other sites
Eat this 2 Posted September 26, 2004 Report Share Posted September 26, 2004 id just keep an eye/ear out then prob not fooked anythin i blew a hose off a pos cav once the fan was intermittent and i never noticed the temp gauge off the scale when boof shhhhhhhhhhhh oooops let it stand overnight filled it up screwed hose back on and np lol Link to post Share on other sites
acf8181 0 Posted September 26, 2004 Report Share Posted September 26, 2004 the 150 deg was oil temp - water went to about 105 -(never went right over to the right anyway) I've just driven about 50 miles with no problems hopfully all okeven so, 150 is very high for oil temp.i don't think they'd be related either...so you may have another problem. Link to post Share on other sites
anorak 0 Posted September 26, 2004 Report Share Posted September 26, 2004 150 degrees is high for oil temperature but I ran a VR Corrado for 2 years and did half a dozen trackdays where the oil temp regularly hit between 140 and 146. (Albeit for just 10 minutes at a time).In fact I used 146 as my cut off point to come in and let her cool down.I'd say just get the oil and filter changed ASAP and if you've got no untoward knocking or smoking you've got away with it.The VR is tougher than you think. 8o) Link to post Share on other sites
Geastb 0 Posted September 26, 2004 Author Report Share Posted September 26, 2004 It was only 150 for about 5min. I'ts only just had oil change 50miles ago so shouldn't it be ok? Link to post Share on other sites
VR6Pete 1,455 Posted September 26, 2004 Report Share Posted September 26, 2004 assuming ur water level went down, you should of got a flashing light to warn you of low levels. Link to post Share on other sites
tommy 0 Posted September 26, 2004 Report Share Posted September 26, 2004 I'd say if you stopped when the engine overheated you should be ok......the damage is done to an engine when you drive it regardless of how hot it gets,.... then things tend to crack and warp................I think your worrying for nothing....if the car is driving with no problems now your fine! Link to post Share on other sites
Geastb 0 Posted September 26, 2004 Author Report Share Posted September 26, 2004 assuming ur water level went down' date=' you should of got a flashing light to warn you of low levels. [/quote']I'll get it checked! Link to post Share on other sites
ingham 5 Posted September 27, 2004 Report Share Posted September 27, 2004 sounds like themostat stuck shut (common on vr s (mine did )) and burst pipe maybe, is themostat old as if it is ,get it changed quick Link to post Share on other sites
Geastb 0 Posted September 27, 2004 Author Report Share Posted September 27, 2004 It was a burst pipe (the one by the oil cooler) Been driving it all weekend and no problems since so fingers crossed its ok! Link to post Share on other sites
ingham 5 Posted September 27, 2004 Report Share Posted September 27, 2004 mine popped same hose . month later thermostatstuck shut (i think for second time) Link to post Share on other sites
