DaveMcK 0 Posted April 30, 2008 Report Share Posted April 30, 2008 hey guys, great site here!Ive a problem with my v6 4motion and i think i need to recode/replace my lateral acceleration sensor.i have access to vagcom but dont know the procedure?Can anybody out there put me in the right direction?ive already looked at this...http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?137864Cheers Link to post Share on other sites
pimpcat 0 Posted April 30, 2008 Report Share Posted April 30, 2008 link bust! Link to post Share on other sites
DaveMcK 0 Posted April 30, 2008 Author Report Share Posted April 30, 2008 apologies, updated! Link to post Share on other sites
Eat this 2 Posted April 30, 2008 Report Share Posted April 30, 2008 what symptoms/problems does it create?? Link to post Share on other sites
DaveMcK 0 Posted April 30, 2008 Author Report Share Posted April 30, 2008 the esp light stays lit on the dash.can anybody help me here, or ever heard of this problem? the answer in the link looks like a good start but a bit more info is needed! Link to post Share on other sites
pimpcat 0 Posted May 1, 2008 Report Share Posted May 1, 2008 try reseting it with the vagcom but if there are faults they do stay in the system for a while i had an esp problem due to the stering angle sensor which wudnt restet but after a week it reset its self Link to post Share on other sites
DaveMcK 0 Posted May 1, 2008 Author Report Share Posted May 1, 2008 i reset it with a mates vagcom twice but it doesnt dissapear. Does anybody know how to recode it?4 Faults Found:01423 - Lateral Acceleration Sensor (G200) 57-00 - Electric Circuit Failure01044 - Control Module Incorrectly Coded 35-10 - - - Intermittent01423 - Lateral Acceleration Sensor (G200) 27-10 - Implausible Signal - Intermittent00538 - Reference Voltage 57-10 - Electric Circuit Failure - IntermittentHere are the faults...Cheers Link to post Share on other sites
petervr6 0 Posted May 3, 2008 Report Share Posted May 3, 2008 ive got the same problem my esp light stays on and my ABS light is also on.mine comes up with code that the abs in incorrectly coded but i had a guy at vw put it on the vag com and he said its that acceleration sensor causing the problem its a black box screwed to a thin bar/bracket i think under the steering colum. Link to post Share on other sites
DaveMcK 0 Posted May 3, 2008 Author Report Share Posted May 3, 2008 i have the new sensor, it is quite easy to get to and quite expensive also... can i just directly replace it or do i need to code it!Dont want to take out the old one and put in the new one and get the same problem again!! Link to post Share on other sites
petervr6 0 Posted May 3, 2008 Report Share Posted May 3, 2008 i think they need coding mate thats what the guy at ve told me anyway.. Link to post Share on other sites
DaveMcK 0 Posted May 3, 2008 Author Report Share Posted May 3, 2008 trip to the old stealer so...all ill be able to afford is beans on toast for the rest of the month! Link to post Share on other sites
pimpcat 0 Posted May 5, 2008 Report Share Posted May 5, 2008 all of ur problems sound like the problem i had with mine just check there is nothing cort by the sensor as mine just started working again! Link to post Share on other sites
petervr6 0 Posted May 5, 2008 Report Share Posted May 5, 2008 mine only seens to do it every noe and then lately doent stay on all the time.. is it the black box with 2 connector going into it with 2 philips screws holding it in place or have i got the wrong part.. Link to post Share on other sites
DaveMcK 0 Posted May 5, 2008 Author Report Share Posted May 5, 2008 if you take off your panel under the steering wheel, rest your head on the pedals and look up you'll see a small box wrapped in bronze looking metal, attached to the steering column. This is your g200 latt acc sensor. there is also a bigger sensor attached- this is your yaw sensor. However i am no expert and have only come across this through research into my own problem. Link to post Share on other sites
pimpcat 0 Posted May 6, 2008 Report Share Posted May 6, 2008 also check u havent got an item stuck in ur tyres like a screw as this also sets it off if it comes on then u turn the car off nd on nd its gone then it could be sumin stuck in the tyre which ive also had Link to post Share on other sites
dale p 62 Posted October 18, 2021 Report Share Posted October 18, 2021 hi guys i know this is old post but having this issue, replaced sensors today and light still on dash, do the new sensors need to be coded via vagcom? Link to post Share on other sites
