DaveMcK
About DaveMcK
Eire
If you were buiding a mk3 vr6 track car, what modifications would you consider making? i'm building a vento (obd1) and just thought i'd see if anyone has advice... its stock atm with a welded cage and 2 bucket seats. what suspension/break pads etc would people reccomend?
If you lift the boot floor there will be a sticker next to the spare tyre displaying loads of info- the power output should be on this in KW, if not then it'll be on page in the owners manual. multiply by 1.34 to get HP.
if you take off your panel under the steering wheel, rest your head on the pedals and look up you'll see a small box wrapped in bronze looking metal, attached to the steering column. This is your g200 latt acc sensor. there is also a bigger sensor attached- this is your yaw sensor. However i am no expert and have only come across this through research into my own problem.
trip to the old stealer so... all ill be able to afford is beans on toast for the rest of the month!
i have the new sensor, it is quite easy to get to and quite expensive also... can i just directly replace it or do i need to code it! Dont want to take out the old one and put in the new one and get the same problem again!!
i reset it with a mates vagcom twice but it doesnt dissapear. Does anybody know how to recode it? 4 Faults Found: 01423 - Lateral Acceleration Sensor (G200) 57-00 - Electric Circuit Failure 01044 - Control Module Incorrectly Coded 35-10 - - - Intermittent 01423 - Lateral Acceleration Sensor (G200) 27-10 - Implausible Signal - Intermittent 00538 - Reference Voltage 57-10 - Electric Circuit Failure - Intermittent Here are the faults... Cheers
the esp light stays lit on the dash. can anybody help me here, or ever heard of this problem? the answer in the link looks like a good start but a bit more info is needed!
apologies, updated!
hey guys, great site here! Ive a problem with my v6 4motion and i think i need to recode/replace my lateral acceleration sensor. i have access to vagcom but dont know the procedure? Can anybody out there put me in the right direction? ive already looked at this... http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?137864 Cheers
