kalv 0 Posted November 9, 2006 Report Share Posted November 9, 2006 Sorry to post in a dead thread, but is there anyway to pull the ball end out (on strut) after it's clipped into the bolt?I was trying to put it together (INXX - away from the car) so could work out what's going on, and guess what, the feckers don't come apart? I've tried pulling it with pliers with the other end in a vice.. no luck? Am I screwed? Link to post Share on other sites
c4mbl 1 Posted November 9, 2006 Report Share Posted November 9, 2006 would have thought it should pull out easily enough. Try it at all angles. Mine just popped out easily enough when i wanted them to. Link to post Share on other sites
binliner 0 Posted November 9, 2006 Report Share Posted November 9, 2006 ou could try fitting it to the car still attached Link to post Share on other sites
SankysVR6 1 Posted November 9, 2006 Report Share Posted November 9, 2006 Don't mean to sound stupid.But have you removed safety pin from thr ball end. Link to post Share on other sites
vr6madmike 0 Posted November 9, 2006 Report Share Posted November 9, 2006 Yep safety pin should be the first port of call, mine were a right swine to get in and out, you can unscrew the socket end from the strut if that helps?? Link to post Share on other sites
