waterwagon 0 Posted August 26, 2006 Report Share Posted August 26, 2006 help and advice please....whats the best way to go with the mk3 in terms of suspension set up, will coilovers upset the handling on country lanes ?? will struts and springs not cut the pace ? whats every ones opinions on this? Link to post Share on other sites
matth76 1 Posted August 27, 2006 Report Share Posted August 27, 2006 I've got the GMAX kit on mine. The kit uses gas shocks as opposed to oil based ones so last longer, and have a full three year guarantee. The Phirm fitted mine and they said in 5 years that they have been supplying and fitting them they have not had one single problem..touch wood. This spring/shock kit cost £200 plus fitting so one of the cheapest...but one of the most over looked due to its low cost. Highly rated on here. My car is a daily driver so suits me fine as I don't do track days. Lowers the car approx 40-45 mm...just perfect looks wise and handling is amazing going round corners. Still retains stock comfort but slightly firmer as you would expect giving you better control. If you have more money and like to do track days then you can spend a lot of money on suspension set ups... but anything is better than the wallowy stock suspension. d111ren 1 Link to post Share on other sites
vr6highline28 0 Posted September 1, 2006 Report Share Posted September 1, 2006 eibachs n koni's completely transform the handling of a vr6 ... im pretty sure this is the best set up ...... not the cheapest but make the car stick to the road ... Link to post Share on other sites
tubby 0 Posted September 2, 2006 Report Share Posted September 2, 2006 I thik i need new shocks on the rear of my car so going to go for coilovers what brand would lower approx 45 mm max and handle like its on rails ?cheers virgin# Link to post Share on other sites
The_0ne 0 Posted September 2, 2006 Report Share Posted September 2, 2006 I've got koni coilovers on mine and the car is rock solid with minimal body roll Link to post Share on other sites
craggsy 91 Posted September 3, 2006 Report Share Posted September 3, 2006 I've got koni coilovers on mine and the car is rock solid with minimal body roll Ditto.......cant fault konis eally Link to post Share on other sites
mk3anni 0 Posted September 3, 2006 Report Share Posted September 3, 2006 Your all forgetting something.ARB's make a huge difference, ideal budget solution is eibach and koni setup with Eibach or Neuspeed ARB's.If you've got money to burn I can reccomend the konigsports and neuspeed ARB's. Mine handles like a dream with this setup. Link to post Share on other sites
craggsy 91 Posted September 4, 2006 Report Share Posted September 4, 2006 Where can you get the Neuspeed ARBs from tho' Steve? but without being silly money Link to post Share on other sites
The_0ne 0 Posted September 5, 2006 Report Share Posted September 5, 2006 Im interested in ARB's as well Link to post Share on other sites
wkd928 0 Posted December 9, 2006 Report Share Posted December 9, 2006 so whats the concensus on the best bang for the buck on a mk3? im trying to keep my car to a budget although i know suspension will make or break the handling.. what do people recomend for less than £300 as best performance wise? the car may make it to the nurburgring at some point:) Link to post Share on other sites
Russ_vr6 12 Posted December 9, 2006 Report Share Posted December 9, 2006 iv got avo coilovers,makes the car like its on rails,bit stiff but i like it expensive tho lol Link to post Share on other sites
rodney 17 Posted December 9, 2006 Report Share Posted December 9, 2006 Everyone has good things to say about the sets listed previously. On that budget I would go for the Koni kit 220 bucks ish! You wont get the arb for that tho - you need another 200 for the arb set. Koni is a good brand and has a good reputation.good luck and there is a fitting guide in premium members section should you need it d111ren 1 Link to post Share on other sites
rosserooni 0 Posted December 14, 2006 Report Share Posted December 14, 2006 so whats the concensus on the best bang for the buck on a mk3? im trying to keep my car to a budget although i know suspension will make or break the handling.. what do people recomend for less than £300 as best performance wise? the car may make it to the nurburgring at some point:)As with most things you get what you pay for! You can achieve a good setup on a budget but if your looking at nurburgring trips i would recommend spending more of a cars budget on suspension than anything else. KW or H&R suspensions are two of the best in the business, check out all the racing series in germany so many people use them... but theyre not cheap. I had a £300 set of konis on my vr for 3 years and was happy with them, then went around the ring in some KW and H&R setup golfs which blew me away, i now have KW suspension and H&R antiroll bars and cant fault them. (WKD928 were u at the nurburgring in that 928 in july?) Link to post Share on other sites
VR6BOY 2 Posted January 2, 2007 Report Share Posted January 2, 2007 I've got koni coilovers on mine and the car is rock solid with minimal body roll Ditto.......cant fault konis eallyI have the same coillies and eibach anti rollbars front and rear sweet set up Link to post Share on other sites
Chrisdut 0 Posted January 2, 2007 Report Share Posted January 2, 2007 koni coilovers for me too, feels great Link to post Share on other sites
vr6madmike 0 Posted January 2, 2007 Report Share Posted January 2, 2007 Well im changing my stock suspension this month and have decided to go for Koni top mount adjustable kit as id rather be able to adjust the ride quality than be stuck with it too hard or soft! I was orginally thinking of Gmax but ive been in a few koni goldfs now and am very impressed! Link to post Share on other sites
GVK 1 Posted January 4, 2007 Report Share Posted January 4, 2007 Ok, it's not a mk3 but another vote for H&R ARB kits, I'm running the 25mm front + 28mm adjustable rear bar on my mk2 VRGot mine from http://www.motorsportworld.co.ukAlong with FK Konigsports, poly bushes, wide track conversion etc etc Link to post Share on other sites
C J BICHO 2 Posted June 2, 2017 Report Share Posted June 2, 2017 my opinion i spend good Money on Eibach Set , the Best Thing i Did on my Life , Link to post Share on other sites
