Everything posted by Scott
aye mine splutters if its low on fuel and you take a right hand bend too hard, or boot it away from a junction - shat meself the first time it did it, also seems to drive better with a full-ish tank. The extra weight even seems to even-out the engine mass. Now for more power.....
not bad mate, they are close to £70 most places. ebay kicks arse.
Help engine stopped working (UPDATE)
Scott replied to Pearsy47's topic in Engine Maintenance and Problems
jeebus mate that sucks. I am rethinking my vr6 ownership meself after all this lol, its one bloody thing after another... -
and you need a 2x2 adaptor to read the codes on the early type as they obviously dont connect to a standard obd plug. Mine was £3 off ebay.
no filter as standard but the pipe isnt meant to leak so you have a vac leak then because of this mate, replace the leaking pipes and there will be no more smell, plus the motor will run better.
was the chain rattly before it died? funny for it to jump if it wasnt slack mate, its a weird one. -
I have no lambda, get 33.5mpg at a steady 65mph. My MAF caused running probs, but the lambda does not, mines obd1 however.
anyone running straight through exhaust
Scott replied to Tris's topic in Engine Maintenance and Problems
they sound too raspy with no resonator mate. Heres my fav sounding VR6, same setup as I have lol: clickyand another guy with similar set up: http://www.youtube.com/user/donvitovr6 clicky - play main vid. -
Pearsy, that vag405 is a wicked tool mate, got one meself, it is epic-ly good and retail is around £200 in halfrauds, grab one bud. Mine is in the boot and goes everywhere wi me, cleared my maf problem with it and it runs perfect now, does immobs, radio codes, etc etc everything. It will pick up any fault codes as well as reset the ecu etc, remember when engine is off but ignition on and scanning, you will always always get an engine speed sensor fail, its just cos it isnt running, goes away when started. Its fake, unless it remains while cranking over on the key...then it is faulty right en -
corrado VR6 conversion help... OBD1
Scott replied to dene4638's topic in Engine Maintenance and Problems
ah ok, no main feed to the instrument panel - I get ye. That has to be the main ignition feed, a huge fuse under the bonnet could be the culprit, near the passenger strut turret. Also check the plug going to the instruments and to the ignition switch, for 12v on at least one thick wire, measure to a known ground point like the ignition barrel body. I assume youve checked all the fuses, there is no specific one for the instruments but fuse 15, 10A is the engine electronics supply, Relay 3 is the engine control module one, maybe these are faulty and so the ecu is not waking up when the ignition -
help reverse light stuck on ???
lol good one -
you mean even in neutral mate, or when in gear and pulling away?
no idea mate, not enough info really to go on, its a swap that only a few folk have done. the fuel pump relay cannot be getting power, I would start there, the clocks illumination comes off the lighting switch to the right, after the fuse and relays. -
soz good point mate, I have an obd1 vr6, keep forgetting the differences. M44 DUB - I live between glenrothes and cupar, and I have a VAG405 Scanner, If you want, I can check your motor for faults again and reset the ecu / immob etc. Chuck me a PM if you need it done mate.
fueling problem on tick over
Scott replied to grafteratwork's topic in Engine Maintenance and Problems
i always reset the mfa once i drive off, i leave it idling to warm up but it'll always give a crappy fuel calculation at that point cos you are burning fuel and not moving, and a low figure from idling will pull the mfa average down when you drive off, just push in and hold to reset it once you hit the road and you will see your getting much more mpg than you thought. -
good idea actually, yeah. Will slap some round the connection box asap.
nice one, I had a list of vag vehicles and the controllers you can access, but have had no response from the abs on my car, but that could be something i can change. Will look out the list and post it so everyone knows what can and cant be done on the mk3.
She's fixed. The vag405 scanner picked up the MAF as being short-circuited, and then open circuited, what seems to have happened is water has gotten into the MAF electronics, shorted it out and caused the running problem. Next when i disconnected it the open circuit code was generated, so I reset the codes after having cleaned the original MAF and it runs perfectly now! Achieves 33.5mpg at 65-70mph, well chuffed. The Autech VAG405 tool is the real hero, cos it seems the ecu refused to run any better unless it was cleared and reset. The battery removal clear had no effect on this, I tried it b
dont unplug the lamp! The faultt will be at the gearbox end. Theres a switch that goes on when you shift into reverse. Its on the gearbox near the end of the shift cable levers -
Polyurethane Bushes!! (UK source??)
Scott replied to NiNjaVR6's topic in Engine Maintenance and Problems
ah soz mate, vibratech are the only game in town for decent vr6 engine mounts im afraid... -
fourseason tuning - click green arrow: http://fourseasontuning.com/?product=14 pap http://www.pap-parts.com/products.asp?dept=4085 vortex http://forums.vwvortex.com/zerothread?id=2302255 bremmer http://www.bahnbrenner.com/vw_audi/products/1858/VR6_Timing_Chain_Kit
mine has never risen above 70, except on a hot summers day, heating is red hot
idle air control valve it sets the idle, if its jammed shut it wont idle cold, or jammed open, wont idle hot. The maf (airflow meter) if open circuit, will make it start but immediately cut out when cold, will idle for about 10 seconds when hot a short circuit maf will run perfect cold, then cut out and refuse to rev when hot (over 60oC oil temp on MFA) Engine coolant temp sensor (ECT) will cause the same symptoms. immob ring will always start first then cut out a few seconds later on the mk3
