Days Won
1
vr6 bez last won the day on September 11 2017
vr6 bez had the most liked content!
About vr6 bez
Gender
bacup
blackwookie reacted to a post in a topic:
Mk4 vr6
Timothy_Ellis reacted to a post in a topic:
Mk4 vr6
It turned out to be the ecu. I had to buy a second hand one from Germany for £100 then pay £100 to get it coded to the car. Seams to be spot on now ??
Bought a new door mec that has sorted the puddle light and interior light but didn't do anything with the starting issues. Tried to change the fuel pump relay no: 409 and that hasn't worked so it's looking like an ecu fault ?
Mk4 vr6
Will let you know bud just fingers crossed it works ??
ah I know what your saying bud. It's just with the fuel pump priming off the drivers door that is what was making me go in this direction. It needs a new door module anyway as the interior lights and puddle light don't work with the door open. It's got to be worth a shot. I'm not 100% this will fix it but it's another thing that does need fixing. It is giving me a PO605 code on the vag com
No it runs sweet as a nut once it's running no missfires or power loss it's just hit or miss weather it will start again once turned off. I have ordered a door module and will let you know if it cures it
It's doing my nut in lol she will start it up fine then go to the shop and when she comes out it won't start ? I'm more swayed to the door module due the the priming issue and it's prob the cheapest fix for now lol thanks for your info will also try looking into them ??
Would this stop the fuel pump from priming? As I have noticed when the pump doesn't prime it won't start so if you keep trying and eventually you hear the pump prime it will start. I have also read if the door module is faulty this can stop it starting. Is this true? Thanks
Hi all I'm having a prob with the mrs v6 4 mo intermittent starting I have plugged in my vag com and it's coming up with a control module prob. I have looked into the po605 code and ppl are saying about a 3" pipe in the ecm ( ecu ) does this sound familiar to anyone and is it an easy fix?
vr6 bez reacted to a post in a topic:
Oh no...how bad really?
that is great guys thanx i was gettin a bit worried thinking i have taken the front end off for nothing
i bought the corbonio kit and it reved up faster also with the decat pipe made hell of a difference, i would go corbonio all the way the only prob is that they have stopped making them now so you would have to get one second hand
i have just changed my air con pump cos i was told that it wasnt workin, so i made sure everything was free and workin right but when i replaced the old one i have found that this one dont work ether as in when i switch it on the middle bit dont move round. does it have to have gas in it to work, i really hope so as i had to take the front end off to change it
Camber Issues with fitting FK coilovers?
vr6 bez replied to 1949bug's topic in Wheels, Brakes, Suspension and Steering
i am glad i have found this post i have just fitted some fk streets to my vr, whats the best way to set them up??? thanx -
hi all, my air con compressor has stuffed it, and i have aquired a replacement. could any one tell me how i go about replacing it or possibly send me a link to a guide. thanks wayne
hi all i know this is a vr6 oc lol i have bought a dirty diesel to run as a daily as it will be cheaper than my vr6 to run, on my way home yesterday the oil light poped up so i pulled over and left it for 5 mins i dipped the oil and it was fine i had a smell of the water to see if it smelt of oil but that was ok, when the oil light came on the rev counter stopped workin and the batt light came on very faint, i set off again as the car had oil and water so it should be ok, when you rev the car up it goes ok but then the light pops up again and every thing goes bad, does anyone have any ideas a
i put a corbonio on mine and found it picked up quite fast, could tell the difference right away
