akz786
Everything posted by akz786
just another question on top of that, wat is the box behind it the plastic one? whats contained within it? as mine has oil around it!
Removing window regulator that doesnt work
akz786 replied to akz786's topic in I.C.E, Security an Electrical
what I mean was that the clamps are at the highest position i.e at the top hence not accessible with a spanner or ratchet. I cant move the glass down as i think the motor has gone. Previously i just chopped the whole regulator using a cutter - but this time i think the regulator is ok and the motor has gone so i dont want to damage the regulator whilst trying to remove it. -
The only problem is the glass is stuck it won't move at all..I can't get at the clamps to free the glass -
I have in the past managed to remove these in the past but when regulator has failed, this time i replaced a new drivers side window regulator last month. Now all i get is a click sound, which suggests its possibly the motor now. I did check all connections etc. any easy way to remove the regulator whist the glass is at the top without wrecking it? those bolts on the clamps seem impossible to access!
1997 VR6 - In-Pro mk4 style ones,no problems for 2 years, except yesterday the dipped for nearside does not work, I have obviously changed the bulb and tried the new bulb on the otherside where it works. side lights and main beams work on both headlights, so strange issue...seems its the connector perhaps? My question is could this be a break in the connector or loom of headlight, anyway i can diagnose this perhaps with multimeter? Thanks
Yes you can...as rule of thumb G11 (old blue stuff) + G12 (old pink stuff) DO NOT MIX G12+ will mix with both of them.... However to increase efficiency, just drain it all out and use fresh G12+, has better properties on its own I believe. Hope this helps.....
*****UPADTE ***** issue resolved! , was HT lead no6 - had no spark to it at all so will get a good set on there - also changed the Lambda sensor which was shot but this did not create the misfire. Thanks for all your help guys
yes on idle, the engine is vibrating as opposed to its normal idle conditon as I can feel this through the steering wheel ...tbh im guessing 5 and yes it could be 4 but I would not be sure - im not confident on pulling HT leads whilst engine is running lol ...any other way i can check this? does anyone reckon a faulty lambda sensor can cause this too?
Hi - im getting a misfire/hesitation like its running on 5 cylinders, I know it could be leads and/or plugs or even coilpack, but when I scanned it with VAG-COM its comming up with Oxygen Sensor (lambda probe) - no signal - my question is, could the lambda sensor cause the misfire/hesitation TIA
lol looks as though me and you have got the same issue. Just a bit of advice the caliper carrier is held with 2 bolts which are known to get seized so if you can get under the car or on a ramp just look at the back with rear wheels off and spray some WD40 or lubricating fluid and leave for few hours one these can come off its easy from there,im sure I have seen a guide somewhere I will have a look and see if i can find you the link
Hi Im going to get mine from GSF near heathrow airport same price as the cheaper one you mentioned apparently the later models use the generic ones which is good for us! Mine is 1997 highline too the problem with replacing these is that you have to take off the caliper brake disc ect so looks like I might as well spend some time and change my rear brakes too!
Idle Issues - VAG-COM Fault Code enclosed..
akz786 replied to VR6Pete's topic in Engine Maintenance and Problems
Thanks I will check that link, I dont mind giving it a go! ...I might even change the temp sender i think mines been changed at some point though as its a blue one? (think theres also yellow and brown) -
is there a DIY guide on cleaning a throttle body for novices like me ? thanks -
saxaphone/horn type noise from engine
akz786 replied to akz786's topic in Engine Maintenance and Problems
Thats interesting as when I listen to it from the car its seems also to be comming from dashboard/scuttle area and not from engine (sounds more interiorish) so could this be some component of the Climatronic pretending to be a jazz player! -
well its more annoying than anything would just be good if it could be confined to a particular area or component at least... A suggestion was made a while ago towards the Secondary Air pump but I would not be too sure about even where this is located ect...VW vortex suggested that on a vento VR6 the noise comes from a certain pipe becoming "pinched" near the front lower end (bumper needs to be removed) im sure this is not where the secondary air pump resides thou? Thanks -
hmm ive got climatronic too, so this could be tied down to a componenet with that? as far as i know the AC pump is no diff than normal AC its the ancillary parts that are diff could be something there? -
Do all of us who have this sound have Climatronic fitted in our cars? -
Which leads and Coilpack did you buy? I have been suggested Quantum leads (original VW I believe) and BERU (from GSF Parts) for the coilpack..are these the ones you replaced with? Thanks
No its not hsd the manifold off, and im not sure if its ecotec? its a 1997 VR6 OBD2 ...I can try take a pic but its def not the alarm lol yeah just strange this sound i mean it does eventually die down much lower than when its cold (at cold its fairly loud in cabin of car) ..does not seem to hinder performance of the car in any way to be honest I noticed a bit of oil around the black plastic box next to the throttle body (left of engine) there plastic pipes going into the throttle (is this the breather? ) im wondering if thats causing it but my intution suggets some sort of valve getting stuck -
oh so this is a common sound on OBD2 cars? lol @ jazz music you put a smile to my face with that comment
