mattp1983
Everything posted by mattp1983
That car was at inters in 2007, on the ukmkivs stand, he has many cars, was speaking to the guy at length over the weekend, he has two HGP R32s, one std R32 in DBP, an Audi RS4 (older type) and a porsche GT2, he had just brought the 2 turbo'd 32s and the RS4 that weekend to the show, the car is very nicely built and very stealthy.
No the OBD1 and 2 MAFs are not the same (the 4 pin ones I mean) They carry different part numbers and if an OBD2 part is used with an OBD1 car then it will not idle, I know this from direct experience. The end part of the part number differs between the 2, incidentally the OBD1 part is dealer only whereas the OBD2 equivelalent is available through GSF. The 6 pin MAFs come on early cars, usually the dizzy models.
I'm up for this, car is just about done, so reckon it should be there.
WHATS THE BEST HT LEADS TO BUY ???
mattp1983 replied to johnODB2vr's topic in Engine Maintenance and Problems
I bought some formula power 10mm leads from ebay on the basis of a few recommendations on here. They use genuine VAG plug ends and are very heavy and look to be very good quality compared to the OE ones I just took off, bargain at £65 posted. -
my mates did that when he bought it and it was the coil pack that had gone.......
OBD1 Cutting out after 10-20 seconds
mattp1983 replied to mattp1983's topic in Engine Maintenance and Problems
Coilpack seems fine, so have ruled that out....... -
I'll take it off and inspect it, thanks mate. Engine was stored in a bodyshop for a couple of years and everything was full of dust, had to replace a fair few ancillary parts. Guess the clicking I'm hearing could be something arcing out, thought it was chains at first but its intermittant and engine has only done 60k. Would the plug leads possibly cause this? I havnt changed those.... -
My MK2 VR6 conversion cuts out about 10-20secs after firing up.... It seems to be over fueling, and just before it dies it starts to miss fire slightly. I have changed: MAF Coolant Temp sensor is brand new New plugs Swapped Relay 109 with a known working one out of my mk4. Vag com shows nothing. It is decatted with boss for lambda probe. Any ideas? Its a coil pack engine.
smaller droplinks??
mattp1983 replied to supadupagt4's topic in Wheels, Brakes, Suspension and Steering
only on mk4 golfs, roll bar touches driveshaft on 2wd ones if they are too low. -
cat adapter for 6 branch manifold....where from..?
mattp1983 replied to DAZVR6's topic in Engine Tuning
most come with it mate, its just not shown in the pic, they wouldnt mount to anything else with those two holes.... Basically there is a donut style gasket, the bolts are sprung and mount into the 3 hole flange which then tightens down to seal the gasket, leaving 3 holes to mount to the cat/decat... -
nope, the diff flanges are sealed, no oil loss, or there certainly shouldnt be...... lol.... Think a lot of french cars lose oil when changing them....
Well I connected the first one, lol..... The new one is from an OBD2 car, there are two extra 2 pin connectors on it, presumably to run auxillary functions directly, guessing air con for a start? There is the single blue wire going to a single pin connector near the gearbox, the main line going to the starter motor?
Just converted my mk2 8v digi to a OBD1 VR6... (coilpack) Car fires up fine but runs rough, over fuels and wont idle, just cuts out unless throttle is held on until oil temp warms up... Once oil and water are at normal running temps it idles perfect... VAGCOM shows.... MAF B+ Short to ground, changed the MAF and repaired the 4-pin plug where insulation was broken on the wires, re soldered wires, heatshrinked and insulation taped each wire individually...... Have a spare crank position sensor to try and a lambda if any of these would help? Also its got a dub power low temp thermostat in there..
VR6 steering wheel (special edition)
mattp1983 replied to Moochalargo's topic in Members Rides and Event Photos
he missed the .uk off.... link fixed... http://www.scott-lloyd.co.uk/ -
yes definately, at worst its worth more than that to break it, and with a little tidying you could double/triple your money selling on or end up with a nice tidy car
cold running thermostat!!!!
mattp1983 replied to Dezmond_vr6's topic in Engine Maintenance and Problems
dubpower do them also, thats what I have in mine. -
already started modding...
mattp1983 replied to sonnys_vr6's topic in Members Rides and Event Photos
Yeah the corrado ones will fit. Not ideal as slightly different spring rate at back but not really noticeable. -
Simplest is to fit your inlet manifold and throttle body and keep your existing OBD 1 setup.
Driveshafts are about £100 ish I think, Ball joints about a tenner and the CVs £40 a pop, so in bits no more than £200. Labour shouldnt be too bad, its an easy enough job, hub nut off, undo ball joint from hub and wishbone, 4 nuts in total and then undo the splined bolts off the inner CV, remove, cut clips off boots, knock CVs off, knock new ones on then refit, jobs a good un, prolly not much more than 1-2 hours with a ramp and good tools, doing it yourself add another hour or so to that on the drive.
I would be up for a meet, live about 10 min from wakey
Well its no where near worth that, its not styled very well and its a bit chavvy for me. In his defence though... R32 brakes, he says the discs are from that, might be aftermarket 6 pots on there, and when he says just finished running it it he means its basically as new which to be fair it probably will be
