blackberry
Everything posted by blackberry
Hi, apologies for this not relating to my vr highline but to our 99 cabrio. I have two problems with the passenger door side and would appreciate help: 1. The passenger leccy window works from the drivers side but not the switch in the passenger door. It's Bern like this before I bought it a few years ago and is just an annoyance. 2. In the past couple of weeks the passenger door will open intermittently. The key goes in and twists the mech fine, you can hear central locking whirring, sometimes everything works, other times you can open from inside, others from the outside, or not at all. A
Ok, thanks for the advice, will get some VW ones and a free Saturday afternoon!
Hi I've been informed that the rear bump stops have gone on my VR6. Before I buy some from VW or GSF, is there any difference and is there a performance alternative? The rest of the car is thus far standard. Oh - and how easy are they to change? Thanks Paul
Ah found it - amp remote! Thanks
Hi I've just found I have one of these fitted to my car but the blue lead is not connected to anything. What should I connect this to? Thanks
Hi I have the same problem, but no solution yet. All I can say is that on my car it's not the dash insert or the fuel sender, so it must be a broken wire or bad earth? I've had the wires around the fuse box checked without any joy. If you get anywhere with it, please let me know. Paul
Thanks - will try thsi once I have the car which should hopefully be this weekend!
Hi I am looking at another Golf to add to the family (we already have a 96 Vr6 highline). this time its a 3.5 cabbie. there are a couple of electrical gremlins on it ad I wondered if you could help? 1 - the front passenger switch does not control the window, it can be from the passenger switch on the driver's door. - is this likely to be the switch that is faulty? 2 - Heated seats - the passenger seat won't switch off - what could cause this? - broken switch / relay/sensor? Thanks in advance for your help!
Hi I've got a 96 Golf Highline and it came back from its service today with some advice notes. They include Front Discs and Pads Flexi hoses cracking Cat Bung Middle Section of Exhaust needs replacing rear caliper balance kit needed Can you help me with how much of this is easy to do / source parts or recommend upgrades over standard? Thanks Paul
I have a wierd problme that has started this weekend. i went to start the car aftre an hour's break and it wouldn't work. When I say it wouldn't work, the lights worked, but nothing else. Turning teh key woudln't start, there were no lights in the dashboard, the cenral locking only worked on the key rather than the alarm remote. All fuses were intact. I replaced the ignition switch about wto montsh ago. Now, I popped the bonnet, turned the key in the ignition and hey presto, it worked! All fine until lunchtime today. Same problem, then I pop the bonnet andit starts again when I turn the key. W
Priceless!
£270 FullyComp 34y.o with 4 years NCB. Car is standard highline, parked on the road, £100 XS
What colour Parcel shelf does a mulberry highline have std?
blackberry replied to m4t_lee's topic in General Chat
Black in my mulberry highline -
Hi Andy Well done on your mk2 conversion! I had a similar problem with my VR6 OBD2. I then cleaned the throttle body with carb cleaner, which got rid of the flat spots and hunting, made it much more responsive, but then took it to an independent to get the basic settings done on the TB as it was idling a bit high. Apparently if you are patient enough, this too would adapt naturally after a few hours of driving! Hope this helps Paul
Hi I need to buy some roof bars for my car and am confused. Thule sell roof bars but only for golfs without sunroofs...which must be every mk 3 golf in the uk? So...... Any idea why Thule won't sell roof bars where there's a sun roof? Is there a difference between the Thule and VW ones? Any idea where I could get some lockable ones second hand rather than paying stealership prices? Thanks Paul Any advice would be great.
Help! Car won't start at all!
blackberry replied to blackberry's topic in I.C.E, Security an Electrical
Hi. Problem fixed - it was the ignition switch! Will get a new one in the morning. For the time being I can start the car by pushing the key further into the ignition barrel whilst twisting it. Thanks for your help! Paul -
Increased Idle - Sticky Throttle?
blackberry replied to blackberry's topic in Engine Maintenance and Problems
Thanks for the suggestion - do I need to do anything before disconnecting the battery? The radio is aftermarket so no codes there! Paul -
Hi I locked my car using the key in the driver's door at lunchtime. When I went back to it to start and drive off, using the alarm remote (non VW alarm system) the central locking worked, key in ignition all warning lights came on and went off but nothing happened when I tried to start it. I can hear the fuel pump working, the blower fan is working, just nothing in terms of starting. It's not even trying to turn the motor. Uptil now it's started everytime with a strong battery. Any suggestions? It's a late 95 OBD2 Golf highline. Is there an immobiliser on the car that is triggered by the door
Hi yeah, it's supposed to do that, but mine is now doing this even when warm! Paul -
Hi I've got an OBD2 golf highline and have come up with a problem. Initially the car bogged down when warmed up. I cleaned the throttle body last night, foudn some loose clamp on the air box tubing and two loose plugs. The plugs were PCV heater by the MAF which was on back to front, and the ECT plug was loose too. Now it starts fine, but has a higher idle and takes a bit of time to settle down. This is not just on start up but also whenever moving into neutral, changing gear etc. Any ideas on what to look for? Thanks Paul
Result! Nice one!
