About russvr6
cirencester
Aswell as my raddo vr6 i also have a mk3 gti 16v and i have no heating in the car. the fan cuts in as it should and i have no over heating problems is anybody able to help as to what could cause this?? Many thanks
i have a corrado vr6 for sale £2300 ono its on the cars for sale my thread name is russvr6
i do think this site is to golf orientated not alot of help with raddo's
bump
my car won't start after i unplugged the ISV
russvr6 replied to Eddy_y's topic in Engine Maintenance and Problems
mine did this when one of the hoses had come off the isv -
i did that the pads aren't sticking its just after i have been for a drive with quite a bit of braking i get home and the discs are red hot and the pads smoke. I have greased the sliders. is there anyway the pads connect to the calliper cos they just seem to sit on the sliders i also think the corrado set up is different to the golf set up?
yeah i done that but thinking of it i didn't grease the the bit where the pad sits would this make them stick
what do you mean push pistons out? i pushed them back in
i changed my front brake pads thursday now every time i come back from a drive my pads are smoking and the discs are red hot
Got my Vagcom cable but vagcom dont recognise it???
russvr6 replied to sirleeofroy's topic in Engine Maintenance and Problems
pretty sure you do need it plugged into the car also what version of windows are you using -
i belive its the crank sensor
yeah thats right but i changed the one on the housing as precausion and it was the cheapest option but i also think the rad fan switch is faulty
The top hose was hot and the bottom was cold apparently the thermostat is common for going on vr's
on vag com it says something about excessive fault codes on ABS but it said that when we had snow Think i want an M5 now
i was racing an M5 when it came to brake it seemed there was no ABS and the brakes smelt like they were burning could it be the ABS sensors are knackerd the light isn't on in the car but i think the bulb has gone cos it doesn't come on when you turn the ignition on
