F1VR6
About F1VR6
    Recaro seat
  1. VR6PETE: 3.68FD only comes from corrado G60,right?! ,cause I got one from passat G60,but i guess that's 3.9,and you say that 3.68 is better,or?Do you by any chance know the code for the exact corrado g60 FD?
  2. F1VR6
    anyone know?
    ok,thanks for the quick reply!
  3. Hi everyone.I'm looking to do the finaldrive swap to my VR6 gearbox.So, does anyone know if the Final Drive from a G60 Passat gearbox is the same as the one from a G60 Corrado gearbox? I found(not sure) that FD from Passat is 3.94 and Corrado 3.68,so,if that's true,is 3.94 FD gona be to short for VR6? Thanks in advance!
  4. ...also,does anyone know if the FD from a passat G60 gearbox is the same as the one from corrado G60?
  5. I was thinking of doing this swap to my VRbox also,so,VR6Pete thankyou for the info.
  6. obd2 doesn't have ICV like the one on the pic!
  7. Hi,maybee a silly question,but does VR6 golf have TC,and how can you tell?
  8. hey,thanks for the aswer.Yes I did cleaned MAF with elctr.cleaner and let it dry.I also suspect in the wires that conect to throttle body(I don't know how to call them),because when I touch them(without taking of the bracket) there is a change at engine work!
  9. Hi there.Can anyone tell me how to clean throttle body on a vr6 obdI?Do I have to take it off from the inlet mani? Also after cleaning MAF car is running at 1000rpm,and sometimes shortly drops in 850,so where is the fault?? I checked in vagcom,two fault codes appeared: crankshaft sensor(engine was off,so probably that's why) camshaft sensor.....I think the codes were 00513 and 00515. So if any could help,it would be very appreciated. P.S. since english is not my basic language,I appologise for any mistakes!
