About mannie
south london
I would start with the thermostat,take it out and test it,it may be faulty.
Anyone know what the AUDI tdi La man racing cars rev to ??
Check your oil level.
Front side lights 501 , H1 for the rest ,that's what is in my standard OEM headlights.
The stealers do sell single leads,tell them the colour you want at time of ordering.
5 batteries !?Surly adding a split charger and some hi-power capacitor should do the trick, are they deep cycle batteries?
Are you using a proper spk plug socket on an extention bar? there is a slight off set there, you should still get enough clearence to the plug without having to remove anything else.
cold running thermostat!!!!
mannie replied to Dezmond_vr6's topic in Engine Maintenance and Problems
GSF do 80c thermostate (gsf part no: 17646), check it has 80c stamp on it.You also need an O ring thermo gasket too. -
Nice looking car amigo,welcome to the site.
Another vote from me.
The passive immobiliser has cut in,you'd need to arm and disarm the clliford before firing the car up,also there should be an override switch somewhere in the car.........welcome back to VR
Check No. 6 plug for wet/dampness.
If only he had use his head !
Nobody wrecks a super car allegedly doing 30mph in residential streets near Children playgroungs . I've only 3 words for Mr Hamilton : You're a F*cking Banker !
Try your local VW breaker yards .
