cav
About cav
North West
and now not well again... can not figure this one out now and starting to get to me. lambda and coolant temp switch changed along with thermostat, water pump. The engine now idles at 1.5k and dips every so often as though it needs to drop (ecu trying etc). Its over fuelling.. probably to the ecu's 25% safe mode. before it had an idle of 1.5k, it idled ok.. but the first 500revs after that, it would be very spluttery, you can get the induction to pop easily -- hence why i say its over fuelling. after that its ok... but when accelerating it would bog down. Searching idle is still there but n
ok... the is 2 different types... 4 pin for the ecu - located on the left of the bank of sensors 2 pin - for the dials - middle another 2 pin on the right is for air con. it is the middle 2pin one you need for the gauges. There will be a part number on the actual sensor.
V.A.G 2008 Arrival times/details - 20th april, Carnforth, Lancs
cav replied to Volksdevil.com's topic in Previous Events
all these vr's in preston.. and i haven't seen one. gis a flash if you see me. -
i also had a search idle rate and running rich.. replaced the lambda sensor and coolant temp switch.. all is well
not even detailed mine yet... but when i do... (prob just before the first 08 show) it will be a 2 day affair
awesome work! how much vibration do you feel from the engine now?
correct... sorted it tonight.. had to connect up the extra connector.. thanks people
what reason would my car not be recognised by vag com? i'm guessing the list could be endless???
I travel to detail... here is a couple of a raddo i did... half way through wet sanding... afters
Post the pictures that make you laugh (could get to be NWS)
cav replied to VR6Lee's topic in General Chat
Moderator edit by: cadguy Moderator edit by: VR6Rich -
Decided to put a stop to things now.... and these twin pots should help once cleaned up... Will hopefully be fitting the bushes and brakes this weekend... will have to as its the only time i can Mod Edit To Resize Pics Moderator edit by: TheGoth
awesome! got to be pleased with those figures
Cheers guys... Couple of new bits from venom - cheers Rich Smoked crystal rears... [img width=640]http://i11.photobucket.com/albums/a191/cav17/cabby/random%20pics/golf-rear.jpg Something to stiffen it up and make it feel better [img width=640]http://i11.photobucket.com/albums/a191/cav17/cabby/random%20pics/DSCF5993.jpg Should have another update tomorrow resized pics, craggsy Moderator edit by: craggsy
got her back and looking good ... plus new lights
cav replied to cabrioman's topic in Members Rides and Event Photos
lol very similar indeed looking very tidy -
10 in the morning (saturday) and it looks as though we hadn't even touched it...
