VR6Will
About VR6Will
UK
Currently riding an RVF400, great bike, quick and very nimble. looking at gsxr of somekind next....
I've only read good things about the schrick springs on vortex, and also autotech. Where did you get your schrick valve springs from Kev? I wouldn't say £120 is especially expensive either?
What uprated valve springs do people go with for the vr6? Currently prepping a head ready to swap out when i replace the head gasket (currently weeping oil) and want to put uprated valve springs in. Any advice would be appreciated
hahahahahahahaha i wouldnt trust anyone or anything from here :-* I stripped 4th gear twice, and 5th gear once. Fitted an 02m now, see how long that lasts
Do they? :s I run a 3" on my 4wd vrt... it is tight but doesnt knock anywhere at all!
Golf syncro RHD Supercharged
VR6Will replied to stuartvr6hi's topic in Members Rides and Event Photos
You'll need to have the rear section exhaust modified if you go haldex stu, still, enough room for a 3" pipe on mine - also done by H&S -
c2 uk
Like Kev says about the boxes, i've stripped 4th and 5th gears on mine on separate occasions, would have throught the 35 would have been just as bad though! I run a GT3076R
i have a gt3076r with .82 exhaust housing. i would go for a gt35r with a 1.06 exhuats housing
Some nice parts you've been collecting, car will be a good one when its finished. What clutch are you going to use with the 02M?
you wanna try squeezing a 3" pipe through a 4wd rear end!
I'm sorry I wasn't aware of other people have had the same cracking issues - I hadn't heard of or read of any other unhappy customers in this country (I did say correct me if I'm wrong). However' date=' my experiences are of five other people (not including myself) who have vrt's and use the SPA manifold and two more still to be finished. The ones which are running don't have an issue, not to say there's a possibility they or I wont though. 1) The gasket alignment wasn't perfect to the head, but did seal and wasn't too much of a worry to me, I didn't have any problems with the t3 or wastegat
