About Brianvr
feltham,heathrow
was thinking of the same thing recently. is it possible to fit maybe a turbo deisel box ,or is it cheaper to change the final drive ratio,or even a differant 5th gear.for lower rpm at moterway speed,as this should give better mpg also.
yeh was looking at getting hubcentric bolt on spacers,or with the correct longer bolts. weres the best plce to get these,on a buget
looking to uprate the front lower arm bushes,and top mounts float about,had powerflex before on my raddo and were ok just never realy seemed to fit 100%. also best place to buy
got to be the bbs.i have the bbs rx2 ,just need a little bit of spacing in my opinion,but mine are 6.5j et43 16 inch,and look like they need to fill arch more.nice wheels,should have been standard on vr6s.
was told that 20mm rear and 15mm front would be o.k. anyone gone any bigger,without uprated susp
i have 15"+16" alloys both et43,what size spacers can i fit without arch rubbing,not lowerd ,yet,std suspention. whats the best value kits to get front and rear. just what to fill the arches,to reliable max.
check your new spark plugs,is poss that the gap could been closed on install,did this misfire before new plugs and leads
sounds like the same as my vr ,does your abs light come on soon after
do they sell them at gsf or will it be main stealers only
ok will check the rings,i think they were a bit rusty,last time i looked,can you buy them seperatly,or do they only come with new discs
Solid VAG rear wishbone bushes
Brianvr replied to bigdong101's topic in Wheels, Brakes, Suspension and Steering
hi will those bushes fit a golf vr6 97 highline,as mine are gone ,was going to get powerflex ect
