Max VR6
About Max VR6
Nice! What raer lights are you running there?
Okay. Jump in the car and start her up from cold, pull away and all seems fine. After a few seconds the clocks (speedo, fuel,temp & rev) all turn off, then on, then off etc. etc. Its driving me nuts! They seem to sort themselves once warm but the hanbrake and ABS light sometimes stay on, even if the clocks are fine. Also, my speakers are fed via one amp in the boot and the amp keeps turning itself on and off and on etc etc. Not sure if linked to above!? I have quickly checked all fuses and fusebox connections and all seems ok. I have also quickly checked amp and head unit connections,
Some new Syncro pics - New wheel pics page 4!
Max VR6 replied to binliner's topic in Members Rides and Event Photos
Lookin lovely fella, what headlights are you running? -
Any piccies of the foot rest?
Trust me, it will definately cause it! You may have been lucky....... Ive heard before that silicon is the best for a quick fix
New coilpack will sort that right away
Im with you on that! Do you mind me askin how much you got for em?
I will also be there, my first time in Fleet..... Again, say hi!!
I would imagine so, mine was done free at VW because i had spent a lot of money the previous month (circa
Same happened to me and it was the coil pack, about
Thanks for that mate, will give it a go!
Sorry to thread jack, but The carbon cannister - is that located below where the induction kit would be in between inner and outer wing (if you see waht i mean) What does it do and is it needed etc? Would like to put a pipe in there to my induction kit from my lower bonrath grille. Cheers!!
Gonna have a go at polishing the Inlet Manifold on my OBD2 engined VR6. Will i have to replace the gaskets as a neccesity or just if they are worn if i take it off the car? The head gasket was done 6 months ago, would they had to have taken the inlet manifold off then ??? Cheers Max
