nogama3 0 Posted July 17, 2006 Report Share Posted July 17, 2006 guys, i recently posted a thread where i changed the ignition barrel and then the car wouldnt start. i have noticed that if i place my old key near the barrel and then start the car it will work. does anyone know how i can get the key recoded or what options do i have before i visit the local vw and get ripped off? Link to post Share on other sites
mk3anni 0 Posted July 17, 2006 Report Share Posted July 17, 2006 Well.Personally, I'd go to my friendly lock smith that codes keys and have a pair of new keys cut......keys cut to the new lock, but coded with the old key.Easy! Link to post Share on other sites
c4mbl 1 Posted July 17, 2006 Report Share Posted July 17, 2006 Well.Personally' date=' I'd go to my friendly lock smith that codes keys and have a pair of new keys cut......keys cut to the new lock, but coded with the old key.Easy![/quote']Id agree, my dad had the same problem, he went to VW and they were gonna charge him almost double the best price he got. Im sure in the end he went to somewhere like Sainsburys, the guy in the there said he can do it, said it would be about £25 because of the code.He tried other places and they either couldnt do it, or were really expensive. :-d Link to post Share on other sites
VR6_Absy 0 Posted July 17, 2006 Report Share Posted July 17, 2006 You may be able to get a key cloned using your old key but i think only VW can code ORIGINAL keys to the car £35.One option u could try is take the chip out of ur old key and put it in ur new key if its chipped, be careful they're stuck in VW keys and they're quite small ;-) Link to post Share on other sites
nogama3 0 Posted July 17, 2006 Author Report Share Posted July 17, 2006 it doesn't look as if you can split the key in half and retrieve/swap the transponder though? Link to post Share on other sites
VR6_Absy 0 Posted July 17, 2006 Report Share Posted July 17, 2006 If you've got a red square on your original key this can be prized out but it ain't easy. Do your new keys have transponders ???? Link to post Share on other sites
richievr 1 Posted July 17, 2006 Report Share Posted July 17, 2006 only vw can code them as far as i know!! it is done by a secure line to vw uk - the old immobiliser codes are transmitted to them, and they send new ones back for the new key...effectively the car is programmed to the key AND the key is programmed to the car !!but you should be able to split the old key in half and CAREFULLY remove the transponder.then you can put it into your new key and it will work..alternatively remove the transponder from the old key and tape it inside the surround for the ignition barrel..this will obviously have the same effect as placing the old key near the barrel as you are doing now Link to post Share on other sites
richievr 1 Posted July 17, 2006 Report Share Posted July 17, 2006 here is my key : - split along the line arrowed : - transponder will be in the gap arrowed (mine does not have one as it is pre '96 - but i have 2 other immobilisers!! )be careful they do break easily but it can be done richie Link to post Share on other sites
nogama3 0 Posted July 18, 2006 Author Report Share Posted July 18, 2006 thanks for the info guys but i have realised that the new key set up is from a non coded car. anyway vw says they cant recode it as the car is too old. some locksmith that can do it quoted me £45 + vat. so ihave taped the key to the ignition barrel and it fits nicely under the plastic steering column cover. Link to post Share on other sites
antera309 3 Posted July 19, 2006 Report Share Posted July 19, 2006 Thread moved to electrical section.The quote of £45 doesn't sound too bad compared to what VW charge mk4 & mk5 owners for key recodes. They cost well over £100. Link to post Share on other sites
ihpj 0 Posted August 18, 2006 Report Share Posted August 18, 2006 For what it's worth, my Wife lost her set of keys and it cost me 16GBP (inc. VAT) for the key (with light) and 40GBP (inc. VAT) to re-code it at Kieth Garages (Aylesbury). Link to post Share on other sites
