About nogama3
guys, which model mk3's came with these as they appear to be very rare.
[moved] recoding of keys for a mk3 golf 96 p reg
nogama3 replied to nogama3's topic in I.C.E, Security an Electrical
thanks for the info guys but i have realised that the new key set up is from a non coded car. anyway vw says they cant recode it as the car is too old. some locksmith that can do it quoted me £45 + vat. so ihave taped the key to the ignition barrel and it fits nicely under the plastic steering column cover. -
it doesn't look as if you can split the key in half and retrieve/swap the transponder though? -
guys, i recently posted a thread where i changed the ignition barrel and then the car wouldnt start. i have noticed that if i place my old key near the barrel and then start the car it will work. does anyone know how i can get the key recoded or what options do i have before i visit the local vw and get ripped off?
go foe some eagle f1's or toyo proxes t1r's ot t1s'
squeeky new discs/pads
nogama3 replied to nogama3's topic in Wheels, Brakes, Suspension and Steering
it was the metal plate at the back that made the noise - all sorted now - thanks for the help. -
clips back on, driving easy and brakng easy - i thought that but the noise is loud and comes and goes. sounds more like metal rubbing something. -
forgot to mention that the squeek goes away at times and then comes back again and its very loud. -
hi guys, i've just fitted new ate power discs + pagid pads to my mk3 golf but it has decided to become mr friggin squeeky since changeover. any ideas what might cause this? thanks
fog relay swith no on a mk3 golf
thanks mate, its the relay for the front headlights i need details for. -
as the title says really, can anyone tell me what no the relay is please - my electricain has told me its a no 10 but vw do not appear to have that. apparently its a 6 pin relay. any help appreciated.
i was lucky enough to get one of ebay for
Guys, need your help big time. My indicators/side lights are playing up. When using the indicators the indicator lights in the dash both flash at the same time and so do the rear side lights and front side lights and front indicator. When braking this happens again. It was embarrassing to drive the 45 minute journey to work this morning with this happening and more importantly dangerous. What the hell is going on? Can anyone please help. I have a golf mk3 tdi. Thanks
thanks guys.
guys, how do you remove the handles on the mk3? i undone the screw at the back but the handle deosn't budge, seems as if there's some hidden screws, any help appreciated.
