Ciaran 4 Posted May 25, 2006 Report Share Posted May 25, 2006 since owning my vr and getting used to the power and now driving more carefully iv discovered that my MPG just got lower all the time.today i discovered a broken wire leading to the plug which goes onto the MAF sensor. any ideas where i can get a new wire and where is the next point on the line i can plug it into??? cost also???or i could just dodgy it up???would this explain my low MPG??? Link to post Share on other sites
gav_113 0 Posted May 25, 2006 Report Share Posted May 25, 2006 cant u solder it back up? Link to post Share on other sites
Ciaran 4 Posted May 25, 2006 Author Report Share Posted May 25, 2006 well if i had a soldering iron i suppose still a bit temporary for me Link to post Share on other sites
Ciaran 4 Posted June 5, 2006 Author Report Share Posted June 5, 2006 anybody an idea where id get a wire to replace the plug from the MAF to the next possible point?? Link to post Share on other sites
ian 182 0 Posted June 5, 2006 Report Share Posted June 5, 2006 Buy a cheap solder iron mate .The MAF sensor kit costs about £280 i believeian Link to post Share on other sites
dellert 0 Posted June 5, 2006 Report Share Posted June 5, 2006 How far from the plug is it? If you have enough space to strip the cable back and join it, you could use a straight crimp and cover it with heatshrink? Easier to do than soldering and gives a good result. Cheap and permanent and not dodgy bodgy at all! All you would need is a crimp and some crimping pliers, even if you get top notch ratchet crimping pliers will only be about £15, which i would as the other kind are hopeless! I use them at work all the time no problems. Link to post Share on other sites
VR6Rob 0 Posted June 5, 2006 Report Share Posted June 5, 2006 the plug is part of the main loom.i imagin its broken right where it comes out of the plug? making soldering or crimping hard.you may find that other vw's of the same age use the same plug and could be worth a trip to a breakers yard to look.if you find one cut it off a few inches from the plug the crimp\solder it to your loom. Link to post Share on other sites
ian 182 0 Posted June 6, 2006 Report Share Posted June 6, 2006 http://www.volkswagenspares.com/Try these for some sparesian Link to post Share on other sites
Ciaran 4 Posted June 6, 2006 Author Report Share Posted June 6, 2006 the wire is actually proken right where it comes out of the plug so soldering is near impossible. all i need is a plug and as rob says a few inches and il cut the wires and rejoin them!! Link to post Share on other sites
clarkie 1 Posted June 6, 2006 Report Share Posted June 6, 2006 this happened to me and every time i accelerated it would bog down and missfire. i soldered mine but coz it was so close 2 the plug it kept breaking and shorting out on the other wire and melted them. so like vr6rob said i would get another plug. stu Link to post Share on other sites
Ciaran 4 Posted June 6, 2006 Author Report Share Posted June 6, 2006 yes exactly whet mine feels like u accelerate and it bogs down and picks up ok after 2k revs!! Link to post Share on other sites
