Another "hunting at idle" thread!
Hi,
Can't get my head aound this one...
Perfect when cold, no hunting, no stalling.
Progressively get worse as it heats up.
Up to full temp she will hunt on idle and stall at lights etc.
Any ideas?
Cheers. *-)
I have recently had a similar problem. no probs when cold but as it gets upto temperature, poor idling and eratic missfire at low revs ( especially when pulling away) until revs up above 2k ( then Ok again) Mine turned out to be HT leads ( even though it had had a brand new set on at Xmas 2005 :@ seems they were nicked when they were put in)i don't know why the temperature of the engine efffected this unless the plugs and leads were getting hot and some expansion somewhere was opening a crack?
Also just had a engine speed sensor problem this last week which towards the end was causing some dodgy running at idle , its probably not this as the main problem I had with this was the fact that the engine wouldn't start at all when warm.
Hope this helps.
Regards.
Moz
