Guest wdf Posted April 18, 2006 Report Share Posted April 18, 2006 okay, this may have been discussed before, but here is questions.1. I have been using synthetic oil, but is it okay to use mineral instead?? 2. the specs say that 15W40 is okay for 0DegC up to 40DegC ambient, is it okay to use this thicker grade?3. Basically, the point of this is that rather than spending £40 for about a gallon of expensive sythetic oil, i would rather use mineral 15W40 oil that I already buy in bulk(as I buy about 15 gallons at a time for all other vehicles which ALL use the same 15w40 oil)4. Note, I also change oil EVERY 3000 miles. Link to post Share on other sites
Seademon 0 Posted April 18, 2006 Report Share Posted April 18, 2006 I use semi synthetic in mine, the one that VW use which is Syntha Silver. I had fully synthetic in it but that is too thin and when the engine gets very hot the oil will break down and not give the required protection. My engine runs a lot quieter with semi synthetic too Link to post Share on other sites
dipped 0 Posted April 18, 2006 Report Share Posted April 18, 2006 gsf do silver can 10w40 or blue can 15w40 which one best Link to post Share on other sites
Seademon 0 Posted April 18, 2006 Report Share Posted April 18, 2006 Silver is what VW recommend so I stick with that Link to post Share on other sites
antera309 3 Posted April 18, 2006 Report Share Posted April 18, 2006 15W40 is a slightly thicker oil that may well be suitable for higher-mileage VR6s, but to be safe I'd stick with VW's recommendation of 10W40 semi synthetic. Link to post Share on other sites
vr200 0 Posted April 18, 2006 Report Share Posted April 18, 2006 i just got some castrol magnatec 10W40 u think that will be ok?? Link to post Share on other sites
antera309 3 Posted April 18, 2006 Report Share Posted April 18, 2006 I've used Castrol Magnatec in a VR6 before without any problems. Likewise with "minor brand" 10W40 Semi Synthetic from my local discount parts store.Synta Silver does seem to be the most highly recommended choice though and this is what I use now. Link to post Share on other sites
vr6madmike 0 Posted April 18, 2006 Report Share Posted April 18, 2006 10 w 40 semi in mine change it every 5k miles tho just to be on the safe side Link to post Share on other sites
ian 182 0 Posted April 19, 2006 Report Share Posted April 19, 2006 I used to use magnatec in my old RS1800 fiesta and had no probs at allian Link to post Share on other sites
RIX 0 Posted April 19, 2006 Report Share Posted April 19, 2006 mobil one 5W50 or castrol rs 10W60. Link to post Share on other sites
Ciaran 4 Posted April 19, 2006 Report Share Posted April 19, 2006 iv been using castrol GTX 5-30 synthetic since i got the car that alright or should i be running something thicker??? Link to post Share on other sites
spindat45 0 Posted April 19, 2006 Report Share Posted April 19, 2006 Id have to say I think thats too thin for a VR m8. I think most on here would agree that a good Semi Synth 10w/40 is your best bet. As far as im aware most engine oils have to be made to a certain specification. Certain manufacturers put additives in the oil which are supposed to reduce the amount of frcition when starting from cold. A good tip is always to buy and oil which carries the latest spec. All oils have an "S" followed by a letter somewhere on the label. When i was in the trade a few years ago it was "SJ". I think its "SL" now but don't quote me. Its a bit like the British Standard Kite mark for oil I think which changes from time to time. Link to post Share on other sites
