jonnyedinburgh 0 Posted February 12, 2006 Report Share Posted February 12, 2006 While trying to find the source of a small coolant leak I was trying to remove a hose from the aux water pump flange. The plastic bottom half of the water pump has come away from the metal top half! The two parts do not fit together now they have become separated (made a crack noise when it came apart), can anyone advise if this is sealed in the factory or can it be resealed by me? I think the leak was coming from the aux water pump as there was water collecting under it but further inspection after removing the pump has eliminated any of the coolant hoses as the source. How much for a genuine vw pump, would anyone recommend GSW or Eurocarparts instead? Is there any way I can join the two parts of my broken pump together again or have i knackered it completely and just buy a new one? Does anyone know the pump part no. as mine has a very faded and unreadable part no on it? Anyone have a diagram of the cooling system showing the aux pump and hoses? thanks for any advice. Link to post Share on other sites
richievr 1 Posted February 14, 2006 Report Share Posted February 14, 2006 the water pump part number is:- 251 965 561Bretail from vw is £92.29pm me and we can talk "proper" prices ...richie Link to post Share on other sites
rwilkinson 0 Posted February 15, 2006 Report Share Posted February 15, 2006 i did this last week too. got if from euro carparts for about 70 quid i think. the new one is a bit more sturdy with srews holding the bottom on! Link to post Share on other sites
just2zang 0 Posted February 15, 2006 Report Share Posted February 15, 2006 does the pump still work? Is there still a leak? If the plastic is just so that it mounts in a tidy fashion behind the engine, I wouldnt worry to much. If its the actual pump you have split in half then dont even think about resealing as you are only going to cause an engine meltdown and a huge bill sooner or later! Link to post Share on other sites
Brianvr 0 Posted February 15, 2006 Report Share Posted February 15, 2006 hi can i just ask is this auxilery pump essential.can you just make and fit a bypass straight through pipe?. Link to post Share on other sites
