VR6Lee 1 Posted January 24, 2006 Report Share Posted January 24, 2006 DOH! !dodge I forgot to tell ya wot happened last night and this morning driving from and to work. My dash cut out ! :| The speed and rev counter all dropped while thecar was in motion and the clock went back to zero.......Didn't effect the VR's performance. Any Ideas...... :? Link to post Share on other sites
cadguy77 0 Posted January 24, 2006 Report Share Posted January 24, 2006 sounds like a nasty short, either in the cluster curcuit board or on the wires connecting. Link to post Share on other sites
VR6Lee 1 Posted January 24, 2006 Author Report Share Posted January 24, 2006 When ya say nasty that worries me......... I gonna take of the chrome battery cover first. Link to post Share on other sites
cadguy77 0 Posted January 24, 2006 Report Share Posted January 24, 2006 did it happen while cornering? might just be a loose connection Link to post Share on other sites
VR6Lee 1 Posted January 24, 2006 Author Report Share Posted January 24, 2006 did it happen while cornering? might just be a loose connectionI have ratteled my head AHHHHH !dodge I did put on the chrome battery cover when I went to the Jct29 meet on Sunday so I have taken it off now so when I leave at 5:30 I'll find out if it was that.But answering ya question no, I was cruising at 50mph 7:10am this morning straight road through Epping Forest.Last night straight road again through Epping Forest. :? :? :? :? Link to post Share on other sites
purple highline monster 0 Posted January 24, 2006 Report Share Posted January 24, 2006 ghosts mate!! only answer!! !amazed seriously though its probably that cover shorting out your battery terminals, get a carbon one! Link to post Share on other sites
cadguy77 0 Posted January 24, 2006 Report Share Posted January 24, 2006 but wouldn't that cut all the electrics in the car (i.e. headlights etc)? Link to post Share on other sites
purple highline monster 0 Posted January 24, 2006 Report Share Posted January 24, 2006 maybe not, it would affect the easiest route first if its only just touching, lose the earth and all that, maybe not for long enough to affect anything else? Link to post Share on other sites
VR6Lee 1 Posted January 25, 2006 Author Report Share Posted January 25, 2006 So far so good fingers crossed...... 8) Link to post Share on other sites
purple highline monster 0 Posted January 25, 2006 Report Share Posted January 25, 2006 did you take the cover off? if it does it again check your earths, unless you had the dash out recently? i doubt anything would come lose behind there? Link to post Share on other sites
VR6Lee 1 Posted January 26, 2006 Author Report Share Posted January 26, 2006 Fucking gone and done it again last night !mistrust Yeah Nick I've taken off the cover I'm wondering about if its the battery is weakor some thing to do with the ignition I put the key in the ignition, turn it then a clicking noise is made the dash goes on & off in a split second!dodge then she starts. Didn't do it this morning......Made sure every thing was turned off when I started her up. Link to post Share on other sites
kilokilla 0 Posted January 26, 2006 Report Share Posted January 26, 2006 Defo sounds like a loose wire mate also ignition module i.e starter switch on back of ignition can cause this prob and i had 1 vr that had a fault in red and yellow wire that goes to ecu just up in bulkhead by ecu that caused this problem all lights and that still worked but wire was earthing out now and again and shutting car down but i would check all alarm and immobiliser wires around ignition before looking elsewhere as this is generally culprit for this sort of behaviour. Link to post Share on other sites
VR6Lee 1 Posted January 26, 2006 Author Report Share Posted January 26, 2006 but i would check all alarm and immobiliser wires around ignition before looking elsewhere as this is generally culprit for this sort of behaviour.Check the alarm someone else said that at work today Link to post Share on other sites
VR6Lee 1 Posted January 27, 2006 Author Report Share Posted January 27, 2006 :? Shhhhhh All's fine at the moment Link to post Share on other sites
purple highline monster 0 Posted January 27, 2006 Report Share Posted January 27, 2006 in my vr`s history mine had a new ignition barrel and module as it was worn, symptom of this was airbag light and ignition not returning correctly every time? could be your ignition barrel its self?? Link to post Share on other sites
john1980 0 Posted January 27, 2006 Report Share Posted January 27, 2006 HIDo you have a lot of keys on your key ring. If you do then take them off as this will cause wear and then drops out abit Hope this helps Link to post Share on other sites
VR6Lee 1 Posted January 30, 2006 Author Report Share Posted January 30, 2006 Fck its done it again........It seems tobe like every other day %-6 Its only the front dash that goesI also noticed the rev counter shoots roundif it was possessed in some way !dodge CARRIE! But when she has warmed up she is fine !mistrust Link to post Share on other sites
petervr6 0 Posted February 20, 2006 Report Share Posted February 20, 2006 my girlfriends car does that its a corsa mind 52-plate be to vauxhall 3times and still doing it. Link to post Share on other sites
VR6Lee 1 Posted February 21, 2006 Author Report Share Posted February 21, 2006 Well, bit by bit, I'm now wondering if its the alternator :? It happens the heated seats are on, lights are full beam, radio is blasting, the heater is blasting = drains the power. Dosen't do it now in the mornings as its light.Alternator. Wot do ya think? Link to post Share on other sites
